Old 03-10-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Shaft coupling removal and reinstallation
The solid coupling is put on and the holes are drilled so half the hole is in the side of the shaft.
Do you drill opposing holes or only on one side? Do you tap the holes in the shaft or just oversize them to the major diameter of the fastener so the shank of the fastener can simply slip into the hole - like a pin or a way oversized grub screw?
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
You may post attachments
You may edit your posts
shaft\coupling tolerance drobarge Gear & Maintenance 7 06-30-2011 05:42 PM
flex coupling/propshaft removal help? MitchM Gear & Maintenance 2 05-08-2011 03:32 AM
Flexible shaft coupling zerubb Gear & Maintenance 1 08-18-2006 11:13 PM
shaft coupling clifsail SailNet Website Technical Support 1 08-15-2006 02:06 PM
prop shaft coupling kurt crowley Atomic 4 2 06-27-2006 03:45 PM
SEO by vBSEO 3.6.1
