Good method for removing old bottom paint - SailNet Community
 5Likes
post #1 of 14 Old 03-01-2012 Thread Starter
Sailor
Gladrags1's Avatar
How effective have people found those mesh paint removing disks to be in removing old layers of ablative bottom paint? I've found that hitting the bottom with a coarse disk works but tends to burnish the metal in the paint, making it more difficult. What do people feel about those blue mesh disks?
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #2 of 14 Old 03-01-2012 Thread Starter
Sailor
Gladrags1's Avatar
clarification
I'm talking about the kind of mesh disk that is used on a power tool. It can be anywhere from 4.5" to 7" in diameter.
Mandolin
Bayfield 36
post #3 of 14 Old 03-01-2012
Senior Moment Member
SloopJonB's Avatar
If by "mesh" you're talking about the disks for angle grinders that look almost like a resinated pot scrubber material, they are fabulous - at stripping paint from aluminium spars, car bodies etc. They remove the finish but don't abrade the substrate - they leave a sort of burnished surface on metal, not a "sanded" surface. They are the first thing I reach for in those cases, even though they can get a bit expensive - they don't last all that long.
Having said that, I have no experience using them on bottom paint. I'd certainly invest in one to see how they worked on that surface. They aren't real aggressive so I wouldn't worry about the gel coat getting damaged by a little carelessness, even though you will be using a grinder to spin them.
If you decide to use them, I'd find a supplier who sells them in bulk - boxes of 10 or 12 if not larger. As I said earlier - using them can get pricy at $7 or $8 each.
SloopJonB is offline
post #4 of 14 Old 03-01-2012
Salinophile
monet's Avatar
Ablative bottom paint comes off very easily when wet and abraded with sanding mesh on a plasterboard sanding tool - an 8x4 plate attached to a "broom handle" by a universal joint. It takes no more elbow grease than holding up a power tool for hours on end and you don't have to inhale the dust!
Gladrags1, jppp and ppiccolo1 like this.
monet is offline
post #5 of 14 Old 03-01-2012
jppp's Avatar
Just answered a a question I was going to ask.
1985 C&C 35 MK 3
jppp is offline
post #6 of 14 Old 03-02-2012 Thread Starter
Sailor
Gladrags1's Avatar
Sounds great! Thanks. I need to locate a cheap source for replacement disks then.
Mandolin
Bayfield 36
post #7 of 14 Old 03-02-2012
Senior Smart Aleck
jameswilson29's Avatar
How effective have people found those mesh paint removing disks to be in removing old layers of ablative bottom paint?... What do people feel about those blue mesh disks?
Very effective. They are also very effective at inadvertently removing the gelcoat.
jameswilson29 is offline
post #8 of 14 Old 03-02-2012
Wish I never found SN!
SimonV's Avatar
Its less than 30 foot water line , just wet sand with 80 grit, nd you dont breath the dust.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #9 of 14 Old 03-02-2012 Thread Starter
Sailor
Gladrags1's Avatar
No, I'm talking about one of these mesh disks.
Mandolin
Bayfield 36
post #10 of 14 Old 03-02-2012
tommays's Avatar
Scrape it as if you sand it all you will absolutely positively GO to deep here and there and have a golf ball bottom
jcase12 likes this.
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
Removing 10 coats of bottom paint... patrscoe Gear & Maintenance 36 01-30-2012 07:19 PM
Removing top layer of bottom paint MarkSF Gear & Maintenance 12 10-29-2011 04:44 PM
Removing Bottom Paint: How far is too far? wesramm Gear & Maintenance 13 09-01-2008 10:16 AM
Removing Bottom Paint Dan Dickison Gear and Maintenance Articles 0 02-23-2001 07:00 PM
Removing Built-up Bottom Paint Tom Wood Gear and Maintenance Articles 0 09-13-2000 08:00 PM
