Winter project..see-through hatch boards - SailNet Community
 2Likes
post #1 of 20 Old 03-04-2012 Thread Starter
They are made out of Lexan sheet, with the frame being red oak finish board sandwiching the plastic.
The Lexan was quite expensive in thicker grades so I used 3/16" - still seems plenty strong, with two layers of 1/4" oak making the thickness up to that of the solid hatch boards. The two layers are handy as you can make the stepped joint between the two boards, easily.
These windows are for use in the dock and at anchor anyway, otherwise I'd have used thicker Lexan.
Faster likes this.
MarkSF is offline
post #2 of 20 Old 03-04-2012
bljones's Avatar
Nice work!
It's 5 o'clock somewhere:
bljones is offline
post #3 of 20 Old 03-04-2012
Looks great..
Just remember that at the dock in the dark those will become absolutely clear/see-through with lights on below.. the smoked colour is only effective 'privacy' when it's brighter outside than in.
Faster is offline
post #4 of 20 Old 03-04-2012
bljones's Avatar
Look through my ports at night, and you get what you deserve.
"When the moon hits your eye, like a big pizza pie..."
bljones is offline
post #5 of 20 Old 03-04-2012
Glad I found Sailnet
Bene505's Avatar
Ewwww.. TMI.
BL,
Why not make a one-piece hatch, since it's not for offshore use? It would be a lot earier to "open" and "close" since you wouldn't be juggling 2 boards.
How much was the thicker Lexan? I'm about to replace some hatch lenses. (And your boards look excellent.)
Regards,
Brad
Great minds discuss ideas;
Average minds discuss events;
Small minds discuss people.
The best minds discuss sailing (and a little bit of politics). I don't know why. It's a mystery!
Bene505 is offline
post #6 of 20 Old 03-04-2012 Thread Starter
Originally Posted by Bene505 View Post
Ewwww.. TMI.
BL,
Regards,
Brad
Regards,
Brad
I didn't make it one piece as I thought it would be too hard to store in the boat. As it is, the 2 pieces just fit under the salon cushion which is where I store the solid boards when under way.
I was thinking I could get some automotive window tint if I want them less transparent.
messer999 likes this.
MarkSF is offline
post #7 of 20 Old 03-04-2012
Closet Powerboater
MedSailor's Avatar
Nice project, looks good.
I did this for my last boat many years ago and learned a few things:
First I did 2 layers of acrylic, ostensibly for insulation like a double pained window. I quickly had to remove the inside layer as it became impossible to see through because of condensation. Drilling several holes in inside layer to let it "breathe" also didn't work. Perhaps if it had been better sealed and I stapled a package of silica gel between....
I also found that smoke plastic didn't deter viewers/voyeurs very much. If it's light below, they can see in. My solution was to put 4 one inch velcro tabs on it, (one per corner) and made up a piece of fabric to velcro in place as a curtain. The curtain could be made of layers of heavy polar fleece or wool for a modicum of insulation.
Why use expensive Lexan? Acrylic is much cheaper, plenty strong for your application, easier to work with (doesn't shatter as easily) and isn't as chemically sensitive as Lexan (Windex instantly ruins Lexan for example).
I loved my transparent hatch. It was amazing how much extra light it let through. Nice project!
MedSailor
MedSailor is offline
post #8 of 20 Old 03-04-2012 Thread Starter
MedSailor
I like the idea for the curtain. It would also protect the plastic in storage a little.
Luckily I had access to a bandsaw which cuts the Lexan like a hot knife through butter. The long blade doesn't get hot and overheat the plastic. I expect it would work well for acrylic too.
I forgot to mention my prime motivation for making these hatches - now I can take the solid boards home and refinish them at my leisure. They need sanding and varnishing.
MarkSF is offline
post #9 of 20 Old 03-04-2012
Lightbulb
Cruising Concept's specializes in quality teak accessories for your new or used sailboat or powerboat.
I have no connection with this company, but their opening set of doors looks really nice. A friend of our has the solid teak version (might be same company, or not) and this makes it really handy to access the interior on a rainy or cold day. In the open position, they lift out of the hinges for total removal if desired.
Notice that they sell an acrylic version.
Not cheap, but OTOH they look like something that an owner could make with some thought and time...
L
olson34 is offline
post #10 of 20 Old 03-07-2012 Thread Starter
Re: Winter project..see-through hatch boards
Yes I do like those too.
MarkSF is offline
Storing/Protecting Hatch boards Tanley Gear & Maintenance 8 03-16-2010 09:05 PM
Hatch Boards Freesail99 Gear & Maintenance 7 03-24-2009 08:41 PM
New Hatch Boards - Pine OK? mstern Gear & Maintenance 31 10-24-2008 08:14 PM
Need new hatch boards in DC FRRizzo111 Gear & Maintenance 1 04-06-2005 09:29 PM
Replace or Refinish Hatch Boards Sue & Larry Gear and Maintenance Articles 0 07-06-2001 09:00 PM
