Which engines would you think twice about - Page 6 - SailNet Community
 18Likes
post #51 of 75 Old 04-05-2012
Re: Which engines would you think twice about
I would' t touch a Volvo. Almost everyone I know who has had one, had nothing but trouble with them.
I remember seeing a bumper sticker which said " Any parts found falling off my Volvo are of the finest Swedish craftsmanship."
davidpm likes this.
Brent Swain is offline
post #52 of 75 Old 04-05-2012
any comments about westerbeke engines
nothingshocking1 is offline
post #53 of 75 Old 04-07-2012 Thread Starter
davidpm's Avatar
Thanks for the warning.
The boat I'm caring for this season has a volvo penta 2002 so I will wear gloves just to be safe.
davidpm is offline
post #54 of 75 Old 04-07-2012 Thread Starter
davidpm's Avatar
I'd say an engine swap with a saildrive would be easier as long as you've got the right adaptor to the sail drive.. the alignment issue is easier with a more stable receiving end (sail drive input rather than a relatively sloppy shaft in stuffing box hose..)
What do you mean adapter?
I thought a saildrive was just dropped into a big hole on the bottom of the boat.
Is it like an engine mount issue? The hole has a certain configuration and you have to have a ring that fits the hole on the bottom and the engine on top?
Never seen one taken apart.
davidpm is offline
post #55 of 75 Old 04-08-2012
Senior Moment Member
SloopJonB's Avatar
It's like an automotive adapter to join an engine and transmission that were never mated at the factory. It's essentially a ring of aluminium with the engine bellhousing bolt pattern AND the different transmission bolt pattern. You bolt it to the back of the engine and then bolt the trans (or saildrive) to it.
davidpm likes this.
SloopJonB is online now
post #56 of 75 Old 04-08-2012
Tell me someone, is the Kubota an overhead valve or overhead cam motor?
I have always liked the OHV motors, and with peak power being about 3000 rpm, that is well within the range of an OHV.
Rockter is offline
post #57 of 75 Old 06-09-2012
My Vetus has been flawless so far . . . been in water in New England last four seasons, starts EVERY time even with low battery slow crank sub zero . . .
mikel1 is offline
post #58 of 75 Old 06-11-2012
BJV
Repowered with a Beta 50 two years ago and am very happy. The US rep office is super helpful and parts are very simple to find, either from the NC office, Kubota and in many cases NAPA.
bvander66 is offline
post #59 of 75 Old 06-11-2012
Learning the HARD way...
eherlihy's Avatar
My Universal M25 (Kubota) is an overhead valve design with the valves connected to the camshaft by tappets and pushrods.
WOT on my engine (no load) is 3K RPM. This is controlled by a governor.
WOT under load is 2600 RPM. I am not sure if this is a problem.
I LOVE that I can buy parts for my engine at the local Kubota dealer for 1/3 the Marine price.
eherlihy is offline
post #60 of 75 Old 06-11-2012
Jetexas's Avatar
To me, the key to an affordable, easy-to-maintain engine is going with something that is still in production.
My boat came with a Westerbeke 10-Two. It hadn't been made since 1987. A new starter was listing for $1000. A head gasket was $350. A rebuild kit was going to be around $4000.
I found a salvage Beta Marine with a Kubota Z482 block, which is still in production. I spent $2k on a new long block and swapped over the marinized parts. Starters are now $80. Complete gasket sets are $50.
Always go with something that is still being manufactured. Even if you have to spend a little more to re-power, you're going to save in the long run.
Jetexas is offline
4-108 Engines dave6330 Gear & Maintenance 5 06-06-2009 05:22 AM
Gas Engines? Classic30 Gear & Maintenance 24 08-06-2008 01:47 AM
engines warwicksail Gear & Maintenance 6 12-14-2007 08:52 AM
engines warwicksail Gear & Maintenance 5 12-13-2007 03:57 PM
New diesel engines Marktesno General Discussion (sailing related) 4 03-06-2001 02:28 PM
