Palmer P60 overheated - SailNet Community
 1Likes
  • 1 Post By SloopJonB
post #1 of 7 Old 03-05-2012 Thread Starter
While coming back into the harbor today, my Palmer quit making water, temp went high. Question: What should I check, strainer and what else, second, how much heat can a Palmer take before serious damage occurs?
thanks, and happy sailing
Rick
rlmccb is offline
post #2 of 7 Old 03-05-2012
Senior Moment Member
SloopJonB's Avatar
Re: Palmer P60 overheated
thanks, and happy sailing Rick
Check the intake, the strainer and the water pump impeller. Is it raw or fresh cooled? If fresh, check the heat exchanger for blockage.
As to heat - did it stop on its own? If so, check that it still turns - isn't seized. I'd change the oil as a matter of course. If it didn't get so hot as to seize, the only likely casualty would be the head gasket - a dead simple change on a flathead.
If it just had a one time overheat, you stopped it before it seized up, it's unlikely to have done any serious damage - get the cooling system checked & operating, change the oil and light it up - if anything was damaged like the gasket, you will know it then.
My money's on some trash blocking the water intake or the impeller fell apart.
SloopJonB is offline
post #3 of 7 Old 03-05-2012 Thread Starter
Was out at the Harbor today to check things out on the Palmer and found the following. I started with making sure the engine wasn't seized, it was not, oil looked good and the same level as before over heating occurred. I started with the water intake and strainer, both were operational, although the strainer did need a good cleaning. From there I went to the impeller housing and took off the cover plate,,,,,,,viola,,,,,,,,impeller was completelly schredded,,,,,,cleaned out as much as I could,,,,,where would any trash that came apart wind up and what problems could it make?? Also anybody have a part number for an impeller for a Palmer 60??????
thanks and Happy Sailing
Rick
rlmccb is offline
post #4 of 7 Old 03-06-2012
You'll have to determine who made the pump.. they are generally aftermarket from Johnson, or Jabsco, or Oberdorfer, maybe Sherwood. Once you have that model and number then finding an impeller should be simple enough.
If the engine is FWC then you'll find the rubber bits in the heat exchanger, and this would be a good time to fish them out. If it's RWC than it's hard to say just where the debris ended up.. if you're lucky the bits were small enough to flush themselves through but you're going to have to be vigilant about the cooling water flow. The blockage (and overheating) may well have been the result of the disintegrating impeller in the first place...
Faster is offline
post #5 of 7 Old 03-06-2012
Tartan 27' owner
CalebD's Avatar
As Faster said/typed, your replacement impeller is dependent upon which water pump is attached to your Palmer.
If it is an Oberdorfer model then Moyer Marine sells them: Moyer Marine Atomic 4 Community - Home of the Afourians - Powered by vBulletin
Everybody has one:
CalebD is online now
post #6 of 7 Old 03-06-2012
SloopJonB's Avatar
thanks and Happy Sailing Rick
Glad your problem was such a routine type occurrence. Lesson learned about routine replacement of the impeller I take it?
As to the highlight - the APPEARANCE of the oil is not an adequate measure of its condition. If the engine overheated, the oil has probably lost much of its additive package etc. The heat can cause components in the oil to boil off.
Pay the $2 and replace the oil and filter. Remember the old ads for one of the oil brands - "Pay me now or pay me later"?
If you have freshwater cooling, after you have picked out all the impeller bits out of the exchanger, change the coolant as well. It can suffer much the same way engine oil does when it goes way past its operating temp.
For the few $$ that some oil & coolant cost, it's not worth messing with.
Faster likes this.
post #7 of 7 Old 03-11-2012 Thread Starter
OK, I cleaned the intake, the strainer, replaced the impeller, pulled bits and pieces of the old impeller from it seemed like everywhere, check the thermostat, changed the oil, drained the carb bowl and changed the fuel filter. Fired up the engine and it purrs like a kitten,,,,,,,,Palmers are truly bullet proof,,,,,,,thanks for all the suggestions and Happy Sailing,,Rick
rlmccb is offline
Palmer 60 troubleshooting rlmccb Islander 2 02-20-2012 08:51 PM
Overheated Diesel -- What Damage to Look For? FishFinder Diesel 9 03-04-2010 02:30 AM
PALMER 60 engine hoagy Gear & Maintenance 5 10-28-2009 09:28 PM
Palmer Johnson 30 owenmccall Boat Review and Purchase Forum 0 03-10-2004 12:42 PM
Palmer p-60 repower ? mrb2222 Gear & Maintenance 0 12-30-2001 10:20 AM
