compass lens haze - SailNet Community
post #1 of 17 Old 03-05-2012 Thread Starter
Daysailor wannabe cruiser
lans0012's Avatar
compass lens haze
Gang,
My cover keeps falling off my compass lens and it's slowly been turning opaque from UV exposure. Is there any product like the ones "as seen on TV" that has worked for anyone to rub the hazing out?
Just looked at new compasses and was thinking you know maybe $99.99 would get me a replacement. I was wrong x 4.
lans0012 is offline
post #2 of 17 Old 03-05-2012
Re: compass lens haze
I had some scratches and haze on my very old compass. I took some wet sand paper, 800 grit, got the scratches out, then polished the whole thing with toothpaste. Looks great!
No problemo!
SkywalkerII is offline
post #3 of 17 Old 03-05-2012
itsaboat's Avatar
I had that issue as well. See this thread: New life for an old compass
Pearson 27
itsaboat is offline
post #4 of 17 Old 03-05-2012
Siamese's Avatar
If you don't get around to polishing it right away, just rub a little mineral oil on it. Available at a pharmacy. Won't hurt anything, and will bring back a lot of transparency with no effort.
Siamese is offline
post #5 of 17 Old 03-05-2012
You can buy a headlight polishing kit complete with polishing pad to put in your drill at any auto parts chain, that will bring it up to a new finish again.
Or you can DIY. The main brand name of plastic polish is "Novus", use #1, 2, 3 in sequence and you can make all the plexi on your boat look new. Sandpaper...probably the long hard way to work on rounded surfaces, compared to a polishing wheel/pad and the right polishes.
Traditional Crest toothpaste (not the gel or fancy stuff) uses diatomaceous earth aka fuller's earth as the "polish" abrasive, and that's also exactly the right stuff to put a fine polish back on plexi or polycarbonate--if it isn't too bad to start with.
If you really want to take it all the way to "brand new" finish up with 3M Finesse, also an auto paint polish but something like a 3000 "grit" equivalent.
If you can find one big cheap pair of athletic white tube socks...that's two compass cover retainers for two bucks.
hellosailor is offline
post #6 of 17 Old 03-05-2012
lans0012 Thanks a lot for posting this and thanks to all contributors for great sugesstions as well.
I have the same problem and was looking for a solution.
Next weekend I will try the Auto Lens restorer kit and post the result.
Cheers,
Tafa
Tafa is offline
post #7 of 17 Old 03-05-2012 Thread Starter
lans0012's Avatar
Thank you for the suggestions gang. I think I'll try one of these and see if I can get a before and after shot up. I figured the auto lens restore would work but didn't want to fall for the infomericial. I think I'll try with some toothpaste first and see what happens.
lans0012 is offline
post #8 of 17 Old 03-06-2012
depending on the make of the compass and if you can get replacement parts ... I've replaced the globe, diaphragm and gaskets on my Ritchie compass .. and it's like new ... way cheaper than buying new!! and not that hard to do ...
RonRelyea is offline
post #9 of 17 Old 03-06-2012
http://www.ritchienavigation.com/doc...hieCatalog.pdf
This is Ritchie's Catalogue. At the end is a list of service centers. In 2008, I mailed my compass to Howard Wilson in Tuckerton NJ, He re-built it to look like new for $65.00.
New compensating magnets, new fluid, new lense and a paint job. Great Service! Nice Guy!
tempest is offline
post #10 of 17 Old 03-06-2012
72 C&C Corvette
CorvetteGuy's Avatar
I agree with skywalker, 800 to a 1000 grit wet sand followed by a toothpaste pollish it worked for my 40 yr old and greatly hazzed compas. cheap and easy with great results.
CorvetteGuy is offline
Hatch lens replacement dillybar Gear & Maintenance 26 03-25-2014 11:27 AM
Opaque binnacle compass lens bfloyd825 Gear & Maintenance 11 04-12-2010 08:53 PM
Malaysia warns Malacca Strait ships as haze worsens (Reuters via Yahoo! Asia News) NewsReader News Feeds 0 10-09-2006 07:15 AM
Malaysia warns Malacca Strait ships as haze worsens (AlertNet) NewsReader News Feeds 0 10-09-2006 04:15 AM
Haze on new cetol ??? skyamsen Gear & Maintenance 2 10-20-2003 06:53 PM
