St 4ooo tiller pilot - SailNet Community
post #1 of 1 Old 03-06-2012 Thread Starter
I claim no expertise but I try (have to). Is any one familiar with the o ring which fits between the electric motor and shaft on the above? The joint between the two pieces according to the disassembly diagram has a wider screw thing that joins the two pieces then a smaller interrupted screw threaded bit with gaps.
Instead of spending a not insignificant amount of money on obsolete gear I thought I would check the basics. Hmm.
Despite being careful not to lose any parts the O ring seemed to be missing. Oddly a metre away was a what I would call a washer square sided about 3 mm thick and about 5 mm difference between internal and external diameter more or less.
I don't have such bits lying around but it isn't what I would call an o ring part no 10 on the diagram although I know parts jump and hide from naiive owners. Anyone any knowledge of this o ring and where it fits? The corrosion suggests it was omitted by the po.
chris_gee is offline
Which Tiller Pilot Flybyknight Gear & Maintenance 13 09-26-2011 11:58 AM
Tiller auto pilot wildlone Gear & Maintenance 10 03-08-2011 12:44 AM
Help with installing a tiller pilot n0w0rries Gear & Maintenance 5 09-30-2009 03:21 AM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
Which tiller pilot to buy? jgsteven Gear & Maintenance 8 03-27-2009 08:11 PM
