Old 03-06-2012
billbone is on a distinguished road
Push Pull Steering
I have a push pull steering system by Yacht Specialties on a '79 Catalina. The steering wheel has quite a bit of play/slack in it - about two inches before you can feel the tension and move the rudder (transom mounted). Is this normal, or is there an adjustment to tighten the slack?
Does anybody know?
  #2
Old 03-06-2012
johnnyquest37's Avatar
johnnyquest37 is on a distinguished road
Re: Push Pull Steering
Attached is the Edson manual for wheel steering systems: http://www.edsonmarine.com/support/P...eringGuide.pdf
On my boat, the steering cables terminate on adjustable bolts. Tighten the bolts to take out the slack. Just make sure to tighten both bolts equally or the wheel won't be centered anymore.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
  #3
Old 03-06-2012
Thanks for replying. You have a single cable push-pull too?
Where are those bolts, inside the pedestal?
  #4
Old 03-06-2012
Sounds like JQ37 is describing typical chain and cable steering rather than what you seem to have. Is this on a C 250?
If the tiller end of the cable doesn't move right away I suspect the problem will be within the pedestal at the drive end - but I haven't been able to find any drawings on line.. they are out of business.
  #5
Old 03-06-2012
Correct - I have a chain and cable system, but the link has the best pictures I've seen of various combinations, so perhaps you can find something analogous. The bolts I described are in the quadrant and anchor the wire rope.
[/B]S/V Wind Orchid
Annapolis, MD
  #6
Old 03-07-2012
Push Pull Steering
Thanks guys. I couldn't find any detailed images of my setup either. When I looked down into the pedestal I think I could see the two bolts. I'll get in there and see if I can make an adjustment. I'll let you know how it works out!
  #7
Old 03-07-2012
Push Pull Steering
By the way, this is a '79 Cat 25.
Tags
push pull steering
You may post attachments
You may edit your posts
Will a 6HP inboard push my 4000# Quickstep? Quickstep192 General Discussion (sailing related) 8 07-26-2011 12:18 PM
Pull-Pull Drive Unit for PDQ 36ft. Catamaran Classic mpdoane2 Gear & Maintenance 1 06-21-2011 09:15 AM
Yacht Specialtys push/pull steering cables Airway Gear & Maintenance 7 05-21-2011 09:48 PM
An old way to travel getting a new push (The Star-Ledger) NewsReader News Feeds 0 04-09-2006 02:15 AM
SEO by vBSEO 3.6.1
