Adding Grab rails and Cam Cleats to Cabin Top - Page 2 - SailNet Community
 2Likes
post #11 of 11 Old 03-07-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Re: Adding Grab rails and Cam Cleats to Cabin Top
Of the 20 some holes I drilled today, only two or three were actually "cored" with wood...
The rest went thru a 3/8" to 1/2" thick fiberglass outer layer then a 3/4" to 1" air space and then the 1/4" inner liner...Inner liner is intregal part and not removeable...
Here' is a shot of a different area, but shows the thickness of the glass build up...
Looks nothing like MS's photo of a deck section, with 1/8" glass, 3/4" wood and 1/8" glass...
Where the wood is supposed to be, I have air space...so drilled a 3/8" hole on outerlayer, and filled the gap with expanding foam...
Then hollowed the foam out to fill with epoxy...
Once this hardens up I can drill it and thru bolt it to the rail with just a pan head showing on the inside...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
Starboard grab rails huguley3 General Discussion (sailing related) 26 08-31-2012 02:10 PM
grab rails makenmend General Discussion (sailing related) 3 11-18-2011 02:12 PM
grab rails divy Gear & Maintenance 0 05-06-2007 08:35 AM
Source for New Grab Rails? Sailormon6 C & C 6 04-20-2007 09:58 AM
Adding ports to the cabin ChrisAndVero Gear & Maintenance 3 02-16-2007 10:46 AM
