8hp Tohatsu/Nissan with Xlong Shaft? - SailNet Community
post #1 of 10 Old 03-07-2012 Thread Starter
Load Bearing Member
CarbonSink62's Avatar
Dock
I searched the forum for info but couldn't find anything recent and I need the latest.
I'm moving up to a Catalina 25 (Yay Me! ) but the boat and engine are both from 1982. Also, I have a wealthy aunt who might be getting very clumsy in June or July;
So an upgrade from the 1982 9.9 Evinrude SailMaster 2 stroke is likely to happen (her home has very steep stairs and her meds make her a little unsteady).
My reading leads me to believe that there is no reason to get the 9.8hp, because all it does is rev higher than the 8.0; as a full displacement hull, I can't use the extra RPM (she could take a bath and slip beneath the water; it happens all the time).
BUT the Tohatsu 9.8 (MFS9.8EFUL) has a 25" shaft and comes with a 8.7"x5.0" 4 blade prop;
The 8hp (MFS8A3EFL) only has a 20" shaft and is listed with a 8.5x8.0 3 blade prop;
(She sometimes leaves the gas stove on and wanders out of the room; very troubling)
I know I can get a better prop for the 8hp, maybe even get it included and not have to pay for the standard one, but the longer shaft is worth the money (about $250 more) because it's deeper (duh!) and swings a slightly larger prop (she invites strangers into her home; it's really just a matter of time).
Long post short (that poor woman; we're all very concerned) does Tohatsu/Nissan offer the 8hp 4stroke with a 25" shaft?
They offer a 6hp SailPro with a 25" leg, why not an 8hp?
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #2 of 10 Old 03-07-2012
Re: 8hp Tohatsu/Nissan with Xlong Shaft?
Try This:
Discount Tohatsu Outboards and Nissan Outboard Motors
Paul T
dabnis is offline
post #3 of 10 Old 03-08-2012 Thread Starter
Load Bearing Member
Dock
Thanks, Paul. I tried them; no 8hp w/ a 25" leg.
Zen Again
post #4 of 10 Old 03-08-2012
Not familiar with your particular boat but would suggest the most powerful motor(to a point!) with the longest shaft that will fit.
Paul T
dabnis is offline
post #5 of 10 Old 03-09-2012
tap
According to the manual, the long shaft is 22.1" not 20". The XL is 27.1". There is a shaft extension kit that costs around $200 that you can get to extend the shaft. Part number is 3V1Q87314-3. I've been thinking of getting it for my motor. But I think maybe the real problem is my motor is too far aft and what I need is a different mounting system.
tap is offline
post #6 of 10 Old 03-09-2012
While there comes a point where strapping too much horsepower on a sailboat is useless, you're fretting over a fairly insignificant difference. In ideal conditions, you may have excess with the larger motor, but you may appreciate that you have the extra juice in less than ideal conditions. Also, you can always run a gas engine at lower power, which is actually better for them to a point.
I would get the 9 and take better care of your Aunt. Your nephew will be eying your boat one day..............
Jeanneau 54DS
Minnewaska is offline
post #7 of 10 Old 03-09-2012 Thread Starter
Load Bearing Member
Dock
Thanks, guys.
My first hope is that the aged Evinrude survives one more season (it's made it this far).
If I had to buy now, I'd go with the 9.8 XL shaft; buying the 8 and fitting a longer shaft wouldn't save me any money, and that's the only reason to get the 8.
Step 2 will be to purchase and fit the remote kit. I'm going with the electric start so the Admiral can fire it up, if needed.
Zen Again
post #8 of 10 Old 03-13-2012
mikehoyt's Avatar
Try this site. Honda & Tohatsu/Nissan Outboards
Is all about Tohatsu and Honda outboards with lots of expert information
Mike
Mike
mikehoyt is offline
post #9 of 10 Old 03-13-2012
tommays's Avatar
The new motor is gonna be WAY to much weight for the old mount so work one into the budget unless the old mount was massive as the new motors are mucho heavy
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #10 of 10 Old 03-13-2012 Thread Starter
Load Bearing Member
Dock
Thanks, tommays.
I'm going up this weekend, I'll get the model of the mount and google it. It is a new one and sure looks sturdy.
I have to assume it was already holding the 9.9 Evinrude but a new 4stroke is probably heavier.
Zen Again
Small outboard charging systems. (Tohatsu/Nissan in specific.) lydanynom Gear & Maintenance 34 01-23-2017 07:37 AM
Nissan / Tohatsu 6h 4 stroke audeojude Outboard 261 09-08-2015 05:59 PM
Tohatsu/Merc/Nissan 6hp mikehoyt Gear & Maintenance 2 06-14-2011 02:50 PM
Nissan/Tohatsu 9.8 high to low altitude waltsn Gear & Maintenance 17 12-13-2009 08:51 AM
Nissan/Tohatsu 9.8 charging system waltsn Gear & Maintenance 12 12-10-2009 07:26 PM
