Testing my trolling motor - SailNet Community
post #1 of 7 Old 03-09-2012 Thread Starter
Hookturn's Avatar
I have a catalina 22 and just got a trolling motor to replace my outboard. I bought the same one the local rental folks use on my same boat. I wondered how long it would run on one charge of my deep cycle battery. I mounted it in a huge garbage can and ran it on the highest setting. It ran for about 2.75 hours. Is this a good simulation of how long it will operate on the water?
Hookturn is offline
post #2 of 7 Old 03-09-2012
Mobnets's Avatar
Re: Testing my trolling motor
Hookturn:
I think it will give you a rough idea, however, its always been my understanding that electric trolling motors are designed for intermittent rather than continuous running, so I've always been leery of using one as a true replacement for an internal combustion outboard on a smaller sailboat. If that is true, I think running it continuously for up to several hours might be tough on it over the long (or perhaps even the short) haul.
Mobnets
1978 Paceship Chance 32/28 "Westwind"
Mobnets is offline
post #3 of 7 Old 03-09-2012
You'll probably find run time extends considerably on lower speeds. How are you recharging? I used one for a couple of seasons on a 20 and 24 foot sailboat, but only to get in or out of canals in calms. I used to recharge ashore.
WanderingStar is offline
post #4 of 7 Old 03-09-2012
Chastened
Ajax_MD's Avatar
If it is a quality, brushless, DC motor then it should stand up to that abuse for a long time, especially if you keep it from getting too hot.
If it's a cheap, Chinese POS from the Wal-Mart sporting goods department, then all bets are off.
If you're interested in going green, you could cheaply rip the powerhead off of an old outboard, and adapt a series-wound, DC electric motor to the output shaft, buy a forklift motor controller, and a potentiometer box for a throttle, and be on your way.
Something like this:
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #5 of 7 Old 03-09-2012 Thread Starter
Hookturn's Avatar
The motor is a Minn Kota, which is supposed to be pretty good quality from what I have read and heard from others. I will only be using it to get to and from the dock, so hope to not need it for more than 15-20 mins at a time. But my fishing buddies often use their motors for several hours at a time on lower speeds and that's what they're designed to do. I trailer my boat so I will be recharging it at home after each use. It is the same size and variety of motor that is used on the local rental sailboats. After talking to the folks there, they have used these motors for the last several years with good results.
Interesting modification Bubble. I like the idea of not having gas aboard in terms of safety, fumes, etc. Does it chew through the batteries or do you get pretty good performance in terms of run time?
Hookturn is offline
post #6 of 7 Old 03-09-2012
johnnyquest37's Avatar
I use a Minn Kota on my dinghy in lieu of a gasoline outboard. I've not yet run out of jiuce, but I only use it to ferry from the anchored boat to shore - 30 minutes or so. Run time is a function of the batter amp-hours available and how fast you are turning the propellor.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #7 of 7 Old 03-09-2012 Thread Starter
Hookturn's Avatar
thanks for all your input. I understand the issues that determine the run-time (and i'm planning on adding another battery at some point). I was just wondering if my test would accurately reflect real use. I can't think of any reason it wouldn't, but figured I'd ask.
Hookturn is offline
hacking a trolling motor hertfordnc Gear & Maintenance 1 10-26-2008 04:05 PM
Trolling motor for dingy? Andyman Gear & Maintenance 7 05-20-2008 10:12 AM
trolling motor for the dingy? hertfordnc Gear & Maintenance 0 05-05-2008 09:30 AM
trolling motor on dinghy RandyonR3 Gear & Maintenance 1 11-10-2007 10:41 PM
Does anyone use a Electric Trolling Motor poopdeckpappy Gear & Maintenance 23 10-19-2007 09:08 PM
