Catalina 30 standing rigging - Page 3 - SailNet Community
 2Likes
post #21 of 46 Old 03-09-2012
One of None
deniseO30's Avatar
Re: Catalina 30 standing rigging
Harbor fright makes a knock off connector
My last project!
deniseO30 is offline
post #22 of 46 Old 03-09-2012 Thread Starter
Harbor freight.....lmao. Denise, that is a serious looking swage tool. $$$$
SV Salinity
alanr77 is offline
post #23 of 46 Old 03-09-2012
I love harbor freight..... However, There's no way I would ever use one of their connectors to hold up a mast....
LOL....
wise4 is offline
post #24 of 46 Old 03-09-2012
I'm curious... If you go with the oversized wire... Are you going to tension it to the original spec or the correct spec for the new wire?
As a side note... It's scary how so many sailboat owners think it safer to under tension their rigging....
wise4 is offline
post #25 of 46 Old 03-09-2012
JimMcGee's Avatar
Just to throw it out there again, I'd contact Hayn and see what they have to say.
Then you have real information to weigh in making your decision.
If you do please post their response.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #26 of 46 Old 03-09-2012 Thread Starter
wise4: I don't tension my rig to any standard spec. I use the recommended range of tension via Loos gauge to get into the ballpark then tune the mast both static and while underway. I agree with the under tension issue but at the same time I have seen boats that you could play music using the shrouds. And then they wonder why they get stress cracks around the base of the mast. There is really no need to go up in size for the rigging on my boat, other than the fact that I tend to bulletproof everything. My OCD forces me to double reverse clamp everything, even above the waterline hoses. I put backing plates under the mounts for my bimini....OCD is expensive. But at least when I drink to much I can trip and fall into my bimini and not have to worry about it ripping out of the base and falling into the water. Instead I bounce off of it and I fall into the water...Someone earlier noted that the cost difference is due to the size difference; however, the cost difference between 1/4" hardware and wires and 9/32" is not much. The strength difference is quite a bit. What I didn't expect was the cost difference between the CD kit and others. However, I did notice that even by staying with the same size 1x19 wire, the cost difference between the CD kit and the Hi-mod kit is alot.
SV Salinity
alanr77 is offline
post #27 of 46 Old 03-09-2012 Thread Starter
Jim, I will as soon as I come up with the right questions to ask. I would imagine that of course they will tell me their stuff is better than what CD uses, and that it's worth evey penny. But I need to know why it's better and why I should pay twice as much. As a fellow C-30 owner I am sure you believe that these are generally well put together boats and that they respond favorably to well thought out upgrades.
SV Salinity
alanr77 is offline
post #28 of 46 Old 03-09-2012
The most female moderator
Donna_F's Avatar
Dock
There's your start for the questions to ask.
Soon as I catch my breath over this re-power, I'll move onto other upgrades and look into the rigging myself.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #29 of 46 Old 03-09-2012
mitiempo's Avatar
Alan
Were you comparing 316 with 316 wire in your pricing? That could account for a fairly large difference in pricing.
I would think going up slightly in wire size would be ok, but certainly not double as you want for some wires (lowers). The only good reason to upsize wire is if the original was wrong which is not very likely. Catalina made over 7000 30's and we would certainly know about it by now.
Wire should be tensioned to about 15% of the wire's breaking load. By going to heavier wire there will be a great deal more tension on the entire boat.
Wire (1 x 19) will stretch the same regardless of its diameter if tensioned to the same percentage of its breaking load. In other words 1/8" wire at 5% of its working load will stretch the same amount (about 1mm for each 2 meters) as 1/2" wire at 5% of its breaking load. The only way your old rigging stretched too much is if it was over tensioned.
You stated you have heavier chainplates, tangs, etc. But you have the same boat. All heavier wire will do when tensioned properly is bend the hull more. And there is nothing you can do about that.
Here is the best rigging guide I have seen, from Selden - they know a bit about rigging. It is a pdf you can download for free. http://www.riggingandsails.com/pdf/selden-tuning.pdf
The best 1 x 19 type 316 rigging wire available today is from Korea. Any good rigger can confirm this. Loos in the US is getting out of the rigging wire business and the riggers I have talked to state that the Korean wire is better than Loos wire as well.
And here is a fact from the Selden guide:
Brian
mitiempo is offline
post #30 of 46 Old 03-09-2012
One of None
deniseO30's Avatar
I like redundancy myself. Like when we would AC and Heat a large building. better multiple smaller units then one large.
On the boat; instead of a split back stay why's not a double? and OK on the headstay for larger. Shrouds, well maybe a secondary Lighter ones for the masthead then replacing the OEM with heavier?
And, emergency rudder, back up gps, back up radar, port and window storm boards, extra coffee, waterproof undies...
My last project!
standing rigging GoodOldBoater North American Yachts 10 04-18-2012 03:21 PM
Standing rigging wdwright1967 Gear & Maintenance 15 03-05-2012 03:40 PM
Standing Rigging Too Old? StillInShock Gear & Maintenance 79 11-23-2011 01:18 PM
Standing rigging- Doing it myself irwin325cc Gear & Maintenance 22 06-30-2011 08:32 PM
New Standing Rigging sv1794 Gear & Maintenance 2 05-13-2005 08:32 PM
