Like Tree1Likes
  #1
Old 03-09-2012
Robinsson Crusoe is on a distinguished road
Lightbulb "Careening" sailboat while floating ?
Is it possible maintain/repair/paint bottom of sailboat by tilting it floating in sea? I assumed at least most modern sailboats would be possible tilt sufficiently for accessing bottom and make at least emergency repair and inspections. I searched Internet for tips and experiences about that - but I found nothing anywhere. While much was mentioned about "careening" using tide.
I have no saiboat myself, but a friend has one equipped with "saildrive" where it could be advantageous getting access to saildrive "leg" for inspection, gear oil exchange, etc without lifting the boat up at shipyard etc. He himself was unsure if this was feasible but did not exclude the possibility.
Has anyone in this forum experience or knowledge about this potential possibility?
  #2
Old 03-09-2012
Re: "Careening" sailboat while floating ?
We have careened a small 24 foot day racer to facilitate scrubbing the bottom .. this was a lightweight (2600lb) boat, rather tender. Using the spin halyard and winch we were able to get perhaps 20 degrees heel by tying off on a float a boatlength or two abeam. It did not go over easily.
The other issue is the boat tends to skid over towards the dock you're working from, so unless you can tie it off across, you end up with little room to work alongside the dock.
Practically speaking getting more than 10 degrees heel this way on a typical cruiser racer (with 35-45% ballast ratio) is probably going to be hard to do. Unless it's absolutely calm conditions trying to do anything other than scrub (ie paint) would be problematic.. you'd still have pretty limited access to the bottom of the boat.
  #3
Old 03-09-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Where is that video of the sailboat using big bags of water (weights) to heel the boat over to get under a bridge that was too high?
Everybody has one:
  #4
Old 03-09-2012
That was impressive but it took what must have been a few tons of water... that amount of force would be hard to develop with manpower. Maybe tying off to a ground point at low tide and letting the tide do it for you would work...
  #5
Old 03-09-2012
deniseO30's Avatar
Lies about her age
Proabaly easier and safer to beach the boat if it's in a tidal area that has enough height of tide. or use beach legs!
  #6
Old 03-10-2012
Thanks "Faster", "CalebD" and "deniseO30" for interesting comments and
answers to my question.
  #7
Old 03-10-2012
klem is on a distinguished road
I have done this a few times with a very small keel sailboat and it is really tough. Finding a way to exert enough force on the end of the mast is pretty tough. I also worry a little bit about damaging the rig since it is a lot of load and all at one point with a very poor lead over your masthead sheave.
To get the boat over far enough to access half the bottom, you really need to exert a lot of force which unfortunately, pulls the boat down a little lower in the water. I remember not being able to get one over far enough one time because the cockpit was flooding. Also, I wouldn't feel very safe working under the boat and there would not be too many ways to put a safety on it.
It can be done but it seems like there would be easier and safer ways to do it.
  #8
Old 03-10-2012
Daydreamer22 is on a distinguished road
Careening was done on square rigged wooden boats by removing all the river rock ballast and stores from within, then the crew of 30 to 50 men would haul the boat on the beach and tip it on one side to repair the other. Just read about this.
Seems the fixed keel of most modern sailboats would make this extra difficult as posted above. Then there is the matter of finding a crew of 30-50.
  #9
Old 03-10-2012
mitiempo's Avatar
Careening a modern boat is difficult.
Get legs. These pics are from Mostly About Boats showing Peter's Vega on the beach near Sooke B.C.
Article on Sailnet here Giving Your Boat Some Legs by James Baldwin as well.
"Careening" sailboat while floating ?-p1000244.jpg   "Careening" sailboat while floating ?-p1000256.jpg
Brian
  #10
Old 03-10-2012
CaptainForce's Avatar
The photos above are frightening to me. There's no way I'd climb aboard such a balanced vessel or be scraping and painting under the turn of the bilge. We careened both of our full keel Morgans at sandy beaches with a >6' tide back in the 70's and 80's, but that was always one side to the shore at a time and a very stable nest. Take care and joy, Aythya crew
You may post attachments
You may edit your posts
"Oily Pollution" and "MARPOL Trash" Placards? SEMIJim Gear & Maintenance 16 11-15-2011 09:39 PM
"Special" vs. "normal" primer for prop? patrickstickler Gear & Maintenance 5 05-20-2011 08:46 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 16 07-28-2008 06:11 PM
"Blue Water Boats?" "Rescues" snider General Discussion (sailing related) 37 07-01-2007 10:21 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
SEO by vBSEO 3.6.1
