Can't find Mast Sheaves replacement - SailNet Community
 1Likes
post #1 of 14 Old 03-09-2012 Thread Starter
talbot's Avatar
I need to replace the 4 aluminum mast sheaves on my Dufour 31. They're so worn I'm surprised they even spin. Each measures 55mm x 15mm x 13mm as best as I can measure. Can't find anything close to that or even a single source with a good selection to choose from via Google. Mauri Pro Sailing are the only site that shows any kind of selection. But nothing close.
Any ideas of where to look or who to call would be very appreciated.
Talbot
talbot is offline
post #2 of 14 Old 03-09-2012
Re: Can't find Mast Sheaves replacement
Not aluminum but ... might look at ... Zephyrwerks - The Sheave Factory
micheck is offline
post #3 of 14 Old 03-09-2012
jsaronson's Avatar
Defender has a few. Look at pyacht.com also
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #4 of 14 Old 03-09-2012
Tartan 27' owner
CalebD's Avatar
Did you check at McMaster-Carr ? McMaster-Carr
They have an amazing variety of stuff.
G20 likes this.
Everybody has one:
CalebD is offline
post #5 of 14 Old 03-09-2012
Shortman's Avatar
Rig Rite has for Selden, Isomat
Shortman is offline
post #6 of 14 Old 03-09-2012
Any decent machine shop should be able to make a set with the old ones as a guide...
Faster is offline
post #7 of 14 Old 03-09-2012
Senior Moment Member
SloopJonB's Avatar
Talbot
Are the sheaves themselves worn? By that I mean the outer grooves where the halyards run.
If it is only the axle holes that are worn, they can be drilled oversize and bushed with bronze or S/S.
SloopJonB is offline
post #8 of 14 Old 03-10-2012 Thread Starter
talbot's Avatar
Thanks, micheck- they don't have to be aluminum since I am changing to all rope halyards anyway. I will check this site.
talbot is offline
post #9 of 14 Old 03-10-2012 Thread Starter
talbot's Avatar
Thanks for all the suggestions. SloopJonB, the axle holes are the only unworn part left, likely because they are already fitted with an integral bushing. The outsides look like they've been gnawed on!
talbot is offline
post #10 of 14 Old 03-10-2012
Tanley's Avatar
Talbot,
As mentioned above, give Rig Rite a call. We've used them for sheaves and traveler stops. Best to know what you want when you call. Not the friendliest people in the world, but they do have aluminum sheaves and they turned around our order in 2 days.
Z-Spar Sheaves
Francespar Replacement Sheaves
Isomat Sheaves & Rollers
Joe
Tanley is offline
Tags
halyards , mast sheaves , sheaves
Source for replacement masthead sheaves? maxbumpo Gear & Maintenance 8 03-02-2011 05:38 PM
Please help me find new sheaves jarcher Gear & Maintenance 14 06-28-2009 08:05 PM
find out some info on mast sailboatman35 General Discussion (sailing related) 3 06-10-2008 03:05 AM
Where to find a replacement tiller bearing? beachbumlou Gear & Maintenance 7 08-22-2007 06:50 PM
URGENT: Trying to find a replacement compressor labatt Gear & Maintenance 21 04-24-2007 07:29 PM
