Propeller drag test under sail. - SailNet Community
 2Likes
post #1 of 22 Old 03-09-2012 Thread Starter
RatHatDiver's Avatar
Thumbs up Propeller drag test under sail.
Good read.
http://www.catamaransite.com/propeller_drag_test.html
Your Dreams minus your doubts equals your net worth(Life favors the fearless)
RatHatDiver is offline
post #2 of 22 Old 03-09-2012
Bradhamlet's Avatar
Re: Propeller drag test under sail.
I have heard all day long to lock up the prop. to get better speed but that is not what my gps says or have found out on my own sailing.
Brad
Bradhamlet is offline
post #3 of 22 Old 03-09-2012
Maine Sail's Avatar
That is my test so if you guys have any questions I can answer them....
paul323 and SloopJonB like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #4 of 22 Old 03-10-2012
MS, you are a marine mechanical stud. I'm surprised the lady posters here haven't suggested you pose for a calendar.
Way cool test. No questions really, just way cool.
Did you ever do any feathering prop tests? Max-prop procedure is..... neutral, engine off, reverse for a few seconds, neutral. It's a whole different ball game than the purpose of this test. I'm just curious what happens in real life if the feathering prop is left in reverse.
Jeanneau 54DS
Minnewaska is offline
post #5 of 22 Old 03-10-2012
HANUMAN
RobGallagher's Avatar
Very interesting. Thanks for posting.
RobGallagher is online now
post #6 of 22 Old 03-10-2012
Maine Sail's Avatar
The drag on hem is so minimal that it would be hard to measure differences. MIT has already done it far more accurately than I could and all the folders and feathering props they tested did very well and had minimal drag...
I do have a brand new Flex-O-Fold three blade in my shop that will be replacing a Max on a friends boat. It will be interesting to see if he can tell a difference. This is being done mostly because the Max can still catch pot buoys where a folder can't....
I am installing a two blade Flex-O-Fold on our boat this spring. We'll see how it does. If it vibrates the Campbell Sailor will go right back on & the FOF will be sold........ Our boat has as close to zero vibration right now as any boat I've ever been on so it will be an interesting comparison..
______
post #7 of 22 Old 03-10-2012
The drag on hem is so minimal that it would be hard to measure differences. MIT has already done it far more accurately than I could and all the folders and feathering props they tested did very well and had minimal drag......
Sorry, I was unclear. I meant, have you ever tested the impact of leaving a feathering prop in neutral as opposed to reverse on its ability to fold or turn the shaft against the motor. All are told to leave a feathering prop in neutral, although, I've always wondered how important that really is.
Jeanneau 54DS
post #8 of 22 Old 03-10-2012
Tartan 27' owner
CalebD's Avatar
Very clever testing as usual and it seems quite conclusive for 3 blade fixed props.
I'm not sure this test answers the same question for my fixed 2 blade prop that is mounted in the dead wood in a cutaway in front of our rudder. With this configuration we can align the prop with the hull theoretically 'hiding' it from being a real drag.
Do you know of any studies that might have been done on fixed 2 blade props with this configuration?
Thanks in advance, as always.
Everybody has one:
CalebD is offline
post #9 of 22 Old 03-10-2012
Maine Sail's Avatar
Pretty hard to test that, and I would guess with a two blade the differences would be less "dramatic", but one thing I have learned is that if the prop begins to spin:
1- It is not as hidden as you thought
2- Is taking the path of least resistance
When we had a Cape Dory 27 with two blade even after I aligned it vertical it would still begin to spin...
______
post #10 of 22 Old 03-10-2012
Assuming you have fairly constant wind, course and so on, GPS speed seems pretty accurate?
Paul T
dabnis is offline
what's the process to test sail a boat? NewportNewbie General Discussion (sailing related) 32 02-22-2012 03:51 PM
Hunter 27e Test Sail ckgreenman General Discussion (sailing related) 14 11-11-2008 10:31 AM
Sail test question - Proper procedure sellingmyboat Boat Review and Purchase Forum 14 08-21-2007 02:02 PM
THE TEST OF TIME - Sail Magazine NewsReader News Feeds 0 07-30-2007 01:15 PM
Cruising with Kids: sv/ Dream Catcher: Test post @ Sail Blogs NewsReader News Feeds 0 04-18-2006 11:15 AM
