Mainsail comes through again with solar - SailNet Community
post #1 of 19 Old 03-10-2012 Thread Starter
tommays's Avatar
http://www.pbase.com/mainecruising/solar_panel
Last season was i was able to kind of sort of keep the battery's charged if you pretended a bit and i really did NOT want to do that this year SO with Mainsail taking out the guess work i got solar
I am not super thrilled with the terminal strip on the Genasun control so you have to be REALLY careful with the wiring and fuse it
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #2 of 19 Old 03-12-2012
Re: Mainsail comes through again with solar
Interesting. Would you tell us how much it cost and what it will produce? And what gear you run?
WanderingStar is offline
post #3 of 19 Old 03-12-2012 Thread Starter
tommays's Avatar
40 watt Sunwize panel and Genasun control 315 dollars
All the stainless mounting stuff was another 179 dollars But its nice because with the hinge units the panel folds up OR down if i have to get in a tight dock space
Its 40 watts and its putting out 2 amps give or take which had no problem bringing up a group 27 and kicking in the ACR to get the matching starting battery
The battery's were down to 12.4 over the winter and there both happy at 12.75 after two days in the driveway with far from ideal sun
Tommays
Northport NY
tommays is offline
post #4 of 19 Old 03-13-2012
Great, thanks.
post #5 of 19 Old 03-13-2012
Lake Sailor
cb32863's Avatar
Tommays - I am assuming that the panel comes with all the necessary diodes and what not? Also, where did you get the mounting hardware & tubing? Finding a vendor for that seems ot be the biggest challenge for me here in the Midwest.
Thanks.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is offline
post #6 of 19 Old 03-13-2012 Thread Starter
tommays's Avatar
Sailrite had the best deal as it all dodger/bimini hardware
It was (3) 1" split clamps (2) 1" tube ends (3) hinges and 36" of tube
Tommays
Northport NY
tommays is offline
post #7 of 19 Old 03-13-2012
Lake Sailor
cb32863's Avatar
Thanks!
Umquam Porro
cb32863 is offline
post #8 of 19 Old 03-24-2012
MainSail is da man. Again. This article will get me off the fence and install something!
I had a question for which I could not find an answer. If I install a 15W or 20W panel, (primarily for topping off batteries), what kind of controller would people recommend? The GV4 seems like overkill for a really small installation (say under 40W).
paul323 is offline
post #9 of 19 Old 03-25-2012
Send a message via Yahoo to dacap06
Thanks for posting this recommendation! I have been wanting to make some mods to my bimini and this will save me quite a bit.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #10 of 19 Old 03-25-2012
Maine Sail's Avatar
You really need to do the math. A PWM may be a good option but a shunting controller rarely is.
A 15W panel is good for "maintaining" a charge not really for "charging".. A 15W panel at max output is about .85A. Multiply that X about 4.5 hours per day at full output = 3.8 Ah's of charging per day, in optimum conditions.
A 400Ah bank, pretty common on a cruising boat, at 80% state of charge from alternator charging, still leaves you with an 80Ah deficit.
80Ah's X Charge Efficiency Losses @15% = 92Ah / 3.8Ah's Per Day = 24.2 days to go from 80% to full on a 400Ah bank.....
For a 200Ah bank cut those numbers in half or about 12 days to replace the the last 20% of bank capacity, IF, the sun shines every day with minimal to no clouds.....
______
-Maine Sail / CS-36T
Maine Sail is offline
Solar deck instead of solar panels ulferlingsson Gear & Maintenance 34 01-31-2013 05:03 AM
What do I do with my old mainsail? sorcerer33 Gear & Maintenance 6 01-24-2012 08:36 AM
PS 37 mainsail DMD Pacific Seacraft 5 09-29-2011 08:47 PM
Mainsail help AllThumbs General Discussion (sailing related) 15 08-25-2008 09:32 PM
New Mainsail Neil07 Learning to Sail 10 07-28-2007 01:01 PM
