Electrical system install - Page 2 - SailNet Community
 2Likes
post #11 of 35 Old 03-11-2012
celenoglu's Avatar
Re: Electrical system install
It is best to get professional help. Boat electrics requires crimped connections, very good isolation against water, proper size wire for each job, etc.
celenoglu is offline
post #12 of 35 Old 03-11-2012
mitiempo's Avatar
benajah
The prices people are suggesting are all over the map so I priced it out with model numbers for you.
DC system - I assume an outboard so only 1 battery bank is required.
I haven't included a charger but a good one could be purchased for $150 to $250
Batteries about $70 each - you want 1 or 2 deep cycle 12 volt marine batteries
Battery boxes for above about $10 each
Fusing Blue Seas 8005 fuse holder $28
" " 5124 80 amp ANL fuse $20
Main Battery switch Blue Seas 6006 $22
Fuse panel " " 4378 $128 (8 circuit panel)
AC system
Marinco 301EL-B shorepower inlet $50
" 50' 30 amp cord 50PCM2 $63
Blue Seas AC panel 8029 $91 (main +1 circuit) If you
want more than one circuit the Paneltronics model #99723138 has
a main switch and 3 circuits for $180
GFI outlet $12 each
Wire (priced at GenuineDealz and they have free shipping)
tinned stranded boat cable
10/3 for shore power inlet to AC panel .70/ft
14/3 for AC panel to circuit .66/ft
14/2 for DC panel to lights, etc .52/ft
6 awg for batteries to DC switch
and then to panel 1.24/ft
In addition you will want lights which don't have to be expensive.
These prices are off the net and are probably not the lowest.
I think if you install everything in logical places it would take a competent person 4 or 5 hours to connect things up properly, using good crimps and heat shrink.
Hope this helps
Brian
mitiempo is offline
post #13 of 35 Old 03-11-2012
ben, any competent marine electrician is probably going to charge you $100 an hour and if he works carefully and methodically, you're looking at a grand in labor even if the estimate is only half of that.
So one might ask, do you have any free time, and how dangerous are you with pliers and a screwdriver?
Really, I'd check online, buy one or three of the basic classic books on boat wiring, figure out which way you want it done. And then just order up from the vendors you'll see recommended online as well, save yourself a grand on the labor. PLUS you'll know where every inch of it is, and you won't find any surprises like "Gee, who spliced the compass lights with zip cord and electrical tape all the way under the cockpit?!"
Honest, if you can connect a garden hose without mass destruction, you can wire up a 22'er just as well as the best electrician. You may wind up buying a crimper, some fittings, investing a hundred bucks in tools and heatshrink, but those tools will pay for themselves MANY TIMES OVER in the thirty or forty years that they will last you--and give you the ability to repair or replace anything in the system in the future.
My only other suggestion to you would be to buy as much battery as you can physically lug into the boat, limited by what you can lift/push and your budget. Never heard of someone with too much battery, it only means you can have a smaller discharge cycle and get longer life and lower lifetime costs out of the battery bank.
And if you've only got an outboard...yeah, you'll want another power source. And you'll want to use high-efficiency lighting, like LEDs, because they're expensive but they're cheaper than any wy to recharge the batteries. But that's something else to look into entirely.
hellosailor is offline
post #14 of 35 Old 03-11-2012
Siamese's Avatar
Notice how people are suggesting you do it yourself, even though you said you prefer not to? Another thing to factor in besides initial high cost of a pro is, if you do yourself, you'll know the system. If it fails you can fix it. If it needs expanding, you can do it.
It's YOUR boat and YOUR electrical system, and YOU get to decide what you really need. What sort of electronics do you anticipate having onboard? Just install a good, expandable system.
One battery? A battery charger if you'll have access to shorepower? Does the outboard generate power? Will you use solar?
We're talking about a simple system on a 22 footer, and the information's out there. Plus plenty of help right here. You could plan your system, diagram it (with wire gauges, etc.), and post here and get good feed back before you do anything.
Siamese is offline
post #15 of 35 Old 03-11-2012
mitiempo's Avatar
I think my estimate of 4 - 5 hours is possible IF the shorepower inlet and panels, AC outlet(s) and lights are in place, wires run and labeled with extra at each end, and batteries in place. What takes the most time is pulling wires from a to b, and cutting for panels, outlets, and installing lights etc.
If he wants to entertain doing it himself as suggested it is not difficult. Good crimpers, strippers, and a heat gun for the heat shrink will run about $100 to $125 probably. The best book I have seen is this one http://www.amazon.com/Boatowners-Illustrated-Electrical-Handbook-Charlie/dp/0071446443/ref=sr_1_5?ie=UTF8&qid=1331505040&sr=8-5by Charlie Wing for $22 (second edition).
Brian
mitiempo is offline
post #16 of 35 Old 03-11-2012
Iím in the process of doing the same thing on a 25í boat. Iíve budgeted $1000 for everything but the lights and so far am on track to stay within the budget. You can see the basic layout in my post.
Rewire suggestions
Catalina 25
tpothen is offline
post #17 of 35 Old 03-11-2012
miti, I don't mean that your estimate is off, only that somehow whenever someone has to come out and bid hourly on a job, you know, it's a boat job. time juts flies when you're having fun. And of course, if you ask the guy to just flat bid the job...then stuff gets rushed. Personally I'm always delighted when someone comes in under bid, under time, and nails the job. Heck, if they show up to start on time, I'm halfway to awed. (G)
post #18 of 35 Old 03-11-2012
There are economical LED options. Such as http://www.amazon.com/Flexible-LED-Ribbon-LEDwholesalers-2026ww-31k/dp/B002QQ48TK/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I350JQKQWZ4S5I&colid=H9Q4PFL5A9PH
1982 Starwind 22 Mk II | Lake Lemon, Indiana |
(Previously posting as LemonHead)
CarpeAquam is offline
post #19 of 35 Old 03-11-2012
The LED tape rolls are NOT an economical option for anyone without an unlimited power supply. They all, ALL, use resistors to every LED to drop the voltage and none of them use voltage regulation in any active sense. that means they may be taking 9easily) twice as much power as properly regulated LED lights or fixtures, and that means...right, lots of expensive solar panels or fuel to keep refilling the batteries.
They're cheap--but not economical.
post #20 of 35 Old 03-11-2012
mitiempo's Avatar
I doubt you will find many that will flat bid the job. And if you do the only way he avoids getting bit is to quote high enough that if there are surprises they are accounted for. I work on an hourly basis.
But like I said, the time consuming part does not require electrical skills - pulling wires and installing panels (without wiring) etc.
Brian
mitiempo is offline
Help With New Electrical System Oldsoul Electrical Systems 44 02-03-2012 10:09 AM
Electrical System Upgrade... jswwrites Gear & Maintenance 0 09-15-2006 07:42 PM
Electrical System Trouble RogerHardman Gear & Maintenance 0 05-28-2006 07:33 PM
Electrical System Ground Tracuman Gear & Maintenance 10 05-09-2006 05:45 PM
Troubleshooting Your Electrical System Tom Wood Gear and Maintenance Articles 0 06-23-2003 08:00 PM
