Electrical system install - Page 4 - SailNet Community
 2Likes
post #31 of 35 Old 03-24-2012
mitiempo's Avatar
Re: Electrical system install
No, not the keel bolts. On an outboard powered boat the system floats, the battery negative is your ground point.
I would also float the AC system, and not connect the AC ground to the DC ground as it serves no purpose.
Brian
mitiempo is offline
post #32 of 35 Old 03-25-2012 Thread Starter
Ah okay. Thanks. That's good news.
Any idea of any web sites that lay the basic principles out dummy simple?
Scary thing...I actually have a degree in engineering. Just not the type that deals in electrical.
benajah is offline
post #33 of 35 Old 03-25-2012
mitiempo's Avatar
If the panel you are buying is from Blue Seas they come with good instructions. Below is an example showing a 6 circuit Weatherdeck fuse panel.
As far as wire termination there is no better site than this: Marine Wire Termination Photo Gallery by Compass Marine at pbase.com
Brian
mitiempo is offline
post #34 of 35 Old 03-25-2012 Thread Starter
Thanks man, you rock.
Another question. On deep cycle battery terminals, you have two spots to connect connectors on each terminal, a fat one like on a car battery and a small one to attach with a nut.
You have an incoming charging run, and an outgoing load run. Can both of these be on the same spot on the battery terminal, just stacked on top of one another, or is there any reason to separate them and put say the charging on the small bit and the load on the big one?
benajah is offline
post #35 of 35 Old 03-25-2012
mitiempo's Avatar
Use the terminal with a nut. Stack the terminals as you will only have 2 or 3 including bilge pump probably - up to 4 is considered ok. I like to keep it to one connection per post, going to a bus and from there branching out, but it is necessary on larger boats with more connections.
The other solution is to put the connections on a powerpost like below and run only one to each battery. They aren't very expensive and you only need a 1/4" one.
Brian
mitiempo is offline
Help With New Electrical System Oldsoul Electrical Systems 44 02-03-2012 10:09 AM
Electrical System Upgrade... jswwrites Gear & Maintenance 0 09-15-2006 07:42 PM
Electrical System Trouble RogerHardman Gear & Maintenance 0 05-28-2006 07:33 PM
Electrical System Ground Tracuman Gear & Maintenance 10 05-09-2006 05:45 PM
Troubleshooting Your Electrical System Tom Wood Gear and Maintenance Articles 0 06-23-2003 08:00 PM
