Old 03-16-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: Seacocks
Originally Posted by MarkSF View Post
Just replaced 3 of the Wilcox-Crittenden bronze tapered valves after 28 years. There was no corrosion, just some wear of the tapered plug and bore preventing a good seal, in turn causing a slow drip from them. They still all turned OK.
There are still 6 of the WC tapered valves working fine. These are the less used ones so have been less subject to wear of the bore.
We'll see how the Groco replacements fare.
If a little wear or wasp waisting was all the problem was, you should have been able to merely lap the cones with valve lapping compound to make them as good or better than new.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #12
Old 03-16-2012
Sea Diamond is on a distinguished road
Re: Seacocks
Again we see the huge benefit of regular maintanance, the least of which is winter lubrication of thru hulls, which is sadly lacking in many sailors today.
  #13
Old 03-16-2012
Maine Sail's Avatar
Re: Seacocks
Mark,
It is very rare that a tapered cone seacock can't be serviced to work as good as new. I think I can only recall one that was ruined and that was because a piece of monel wire fell down the sink drain and the owner closed the seacock on it..
I have lapped some very, very bad wear out and the valves went on for many more years of service...
Servicing Tapered Cone Seacocks (LINK)
______
-Maine Sail / CS-36T
You may post attachments
You may edit your posts
Seacocks SloopJonB Gear & Maintenance 1 01-01-2012 09:16 PM
seacocks again redhead78 Gear & Maintenance 2 01-18-2010 06:59 PM
Seacocks chris_gee Gear & Maintenance 10 01-17-2009 01:57 AM
Seacocks - Again MeCaptainBinky Gear & Maintenance 13 10-19-2008 10:10 PM
Seacocks - Who Needs 'em? SeaStrutter Gear & Maintenance 20 02-20-2007 02:43 PM
SEO by vBSEO 3.6.1
