PSS Dripless black spray - Page 2 - SailNet Community
post #11 of 14 Old 03-14-2012
Re: PSS Dripless black spray
When you burp a PSS, should you put any grease under the seal? I've not had one, but have similar dripless seal that does suggest grease. The black has to be coming from something. It would creep me out.
Jeanneau 54DS
Minnewaska is offline
post #12 of 14 Old 03-14-2012
Seņor Member
PorFin's Avatar
Minne,
The black is simply graphite that is wearing off of the face of the bearing/seal.
PorFin is offline
post #13 of 14 Old 03-14-2012
bjung's Avatar
The installation instructions for my PSS seal specify to keep it free of grease, as it could cause leakage. The graphite splatter is normal.
I recommend checking the set screws periodically. The collar had moved about 1/4 " and reduced the pressure of the bellow against the graphite on my boat and started leaking heavily. Luckily I was onboard and heard the water, or I would have needed scuba gear to get down into the cabin.
I now have a mark on the shaft where the collar should be and check periodically for tightness.
bjung is offline
post #14 of 14 Old 03-14-2012
itsaboat's Avatar
When I haul the boat out later this year, I am replacing the traditional stuffing box with a PSS dripless system. I plan to use a Ruland clamp collar as Maine Sail suggests. The Ruland Clamp Collar photo - Compass Marine photos at pbase.com This seems like pretty cheap insurance against collar slippage.
Pearson 27
itsaboat is offline
PSS Dripless Bearing weephee General Discussion (sailing related) 2 04-06-2010 12:38 PM
Dripless or not??? irwin325cc Gear & Maintenance 8 12-31-2009 10:32 AM
Sea Spray 15' Cat Marigaux Boat Review and Purchase Forum 9 04-09-2009 02:42 AM
Black smoke and black water bruceyp Gear & Maintenance 25 08-04-2008 01:00 PM
Dripless Packing mgotro@sbcglobal.net Irwin 3 05-25-2006 08:41 PM
