Air conditioning on a small sailboat - Page 2 - SailNet Community
 2Likes
post #11 of 21 Old 03-15-2012
Daysailor wannabe cruiser
lans0012's Avatar
Re: Air conditioning on a small sailboat
Hey do this and save yourself a lot of hassel. Pick out a 1/2" peice of plywood and cutout a rectangle for a cheap a/c unit. I used a couple of right angle brackets to make it snug and sealed it up with Foam in a can.
All of this can be bought at a hardware store including the AC for around $130.
Mine is a 5k BTU model and keeps my CAL 27 cabin cool on Tampa Bay in the summer. It also really does a good job of keeping the interior dry.
When it's time for sailing just stick in the v berth or leave it in the dockbox.
I also rigged up a drain tube that allows it to drip into the scupper. This setup is very common on the docks around here. Especially on the smaller and cheaper boats.
lans0012 is offline
post #12 of 21 Old 03-16-2012 Thread Starter
Thanks, lans0012 -
I've done this before but, on a Nonsuch my head will be just a few feet away from the A/C so i'm looking at mounting something on to/in to the bulkhead.
Cheers Essemm65
Essemm65 is offline
post #13 of 21 Old 03-16-2012
AEOLUS II
WouldaShoulda's Avatar
ians0012,
That is so awesomely simple it can not possibly work!!
WouldaShoulda is offline
post #14 of 21 Old 03-16-2012
That is what we did on our old O'day 322. We referred to it as the Redneck Yacht Club AC system.
The vented type could definitely do the job and if you can find a place for it would be far less hassle. We tried on on our O'day but couldn't find a place for it that didn't require more compromise than we could accept.
PalmettoSailor
s/v Palmetto Moon
1991 Catalina 36
PalmettoSailor is offline
post #15 of 21 Old 03-16-2012
bljones's Avatar
Originally Posted by Essemm65 View Post
Thanks, lans0012 -
Cheers Essemm65
Well, that's one way to drastically reduce the price of a Nonsuch...for the next buyer.
It would have to be a damn narrow unit to mount in the bulkhead- there isn't much room.
If the challenge is the humidity, i'd suggest a small dehumidifier that you can set up anywhere, with a fan blowing over it.
It's 5 o'clock somewhere:
bljones is offline
post #16 of 21 Old 03-16-2012
johnnyquest37's Avatar
Get a new girlfriend.
T37Chef likes this.
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #17 of 21 Old 03-18-2012
now that must be the cheapest and simplest approach, one who likes it HOT!!
stevensuf is offline
post #18 of 21 Old 03-18-2012
Originally Posted by deniseO30 View Post
lol, in the hvac biz..AC is 18-20 degrees inside temp lower then the outside temp.
It's the low humidity that makes it comfortable. If a unit can bring you down to 70 on a 100 degree day it's over sized, but some people like that.
I'm no AC guy, but I think you are wrong on this. A Typical AC unit will bring the temp down about 15-20 degrees. Thats the return air temperature, not the outside air temp. if the boat's interior temp is 100, then the AC will only output 80-85 degree air. As the boat slowly cools down to 80, then it's outputting 60-65 degree air. Of course, depending on conditions, it can only go down but so far.
On my boat, at night, even with outside temp at 80, I could easily get my interior temp down to 50, or probably, mid 40's
Catalina 34
chuck53 is offline
post #19 of 21 Old 03-20-2012
BreakAwayFL's Avatar
For our Coronado 25, we just bought a $300 6000 BTU portable unit. When in use it can sit on the counter in the galley. The exhaust hose will go out a companionway door I am crafting with an exhaust hole cut in it, and the drain will drip drip drip right into the sink and out to sea.
It will fit comfortably in the deck box when not in use, and if we want to take it to sea it will fit in a storage compartment in the cockpit very easily.
$300, done. 6000 btu in that boat should have icicles forming on our noses.
My initial idea was to get one of those RV rooftop units, but they don't look like they can be easily put on and off as needed. I love the hatch a/c at WM, but I don't have $1500 to spend!
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
BreakAwayFL is offline
post #20 of 21 Old 03-21-2012
T37Chef's Avatar
crude but
Shawn
T37Chef is offline
Sailboat Air Conditioning? 1970Columbia34 Gear & Maintenance 33 08-25-2010 08:30 PM
car topping a small sailboat. Grandalf General Discussion (sailing related) 4 08-02-2009 12:46 PM
identifying a small sailboat wmhenrygreen General Discussion (sailing related) 1 01-10-2009 10:18 AM
How can i find a very small sailboat used? RCR Learning to Sail 19 12-05-2007 07:40 AM
Looking for small sailboat jrencher Boat Review and Purchase Forum 8 06-20-2006 10:08 PM
