Air conditioning on a small sailboat - SailNet Community
 2Likes
post #1 of 21 Old 03-14-2012 Thread Starter
Hello All -
My girlfriend is asthmatic and it gets awfully muggy here in Toronto. I'm getting either a Nonsuch 22 or another vessel in the 25' - 27' range and want to instal a proper A/C unit that runs off dockside 110 volts (not DC off battery) BUT...
ideally don't want it seawater cooled (cuz I HATE making holes in the hull - the less the better). I've owned a Cruisair drop-in-the-hatch (heavy, noisy, crafty, ugly but BOY will it freeze you out !!) and don't want that again.
Any thoughts ?? Any input would be appreciated.
Thanks
Essemm65 is offline
post #2 of 21 Old 03-14-2012
Lake Superior Sailor's Avatar
Re: Air conditioning on a small sailboat
Do you really need the cooling or could you just filter the air?..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 21 Old 03-14-2012 Thread Starter
Thanks, Dale.
I DO need the cooling - (but not the FREEZING).
Cheers
Essemm65 is offline
post #4 of 21 Old 03-14-2012
Keep air conditioner on dock & pipe it in? ...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #5 of 21 Old 03-14-2012
One of None
deniseO30's Avatar
All proper Marine units use sea water for cooling. A free standing portable unit that uses a vent tube would be a good choice.
"portable ac units" - Walmart.com
My last project!
deniseO30 is offline
post #6 of 21 Old 03-14-2012
AEOLUS II
WouldaShoulda's Avatar
Originally Posted by sidney777 View Post
I have seen the "portable" AC used. @6000 to 12,000 btu sizes.... It is the newer type of ac for offices, homes, etc.... The AC unit sits inside and it has @5 inch flexable hose (kinda like a clothes dryer hose) out of the back. This hose exhausts the hot air. Theses ac units are more expensive than window units.
The Walmart examples linked above appear more expensive and heavier.
I like the idea of it not sitting in the companionway like a wall unit however.
WouldaShoulda is offline
post #7 of 21 Old 03-14-2012
I tried one with the hose inside the cabin it did not work for me still to hot. as for freezing the thermostat must not have worked. you set it to the temperature you like and it controls it and keeps the temp constant.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #8 of 21 Old 03-14-2012
One of None
deniseO30's Avatar
lol, in the hvac biz..AC is 18-20 degrees inside temp lower then the outside temp.
It's the low humidity that makes it comfortable. If a unit can bring you down to 70 on a 100 degree day it's over sized, but some people like that.
My last project!
post #9 of 21 Old 03-15-2012 Thread Starter
Hi Denise -
OK... you KNOW yer onions about A/C. I'm talking about the small interior of a Nonsuch 22 and I am liking the idea of some reasonable bulkhead mounting of a 5000 BTU 'portable' unit as close to the cabin top as I can with a single exhaust hose being vented 'outside' somehow. At around 6' of headroom, the cabin space must be around 7' of beam by 10' in length i.e. roughly 70 sq. ft or 420 cubic ft.
I would imagine that this would do the trick - what say you (and thanks, BTW)
Essemm65 is offline
post #10 of 21 Old 03-15-2012
AEOLUS II
One way or another, I want to be camping dockside mush more often this summer!!
Sailboat Air Conditioning? 1970Columbia34 Gear & Maintenance 33 08-25-2010 08:30 PM
car topping a small sailboat. Grandalf General Discussion (sailing related) 4 08-02-2009 12:46 PM
identifying a small sailboat wmhenrygreen General Discussion (sailing related) 1 01-10-2009 10:18 AM
How can i find a very small sailboat used? RCR Learning to Sail 19 12-05-2007 07:40 AM
Looking for small sailboat jrencher Boat Review and Purchase Forum 8 06-20-2006 10:08 PM
