Dyneema Lifeline Hooks - SailNet Community
post #1 of 7 Old 03-14-2012 Thread Starter
Superior Sailor
Squidd's Avatar
I want to replace my frayed covered steel lifelines with dyneema rope...
The rope has a 5400# rating, but the heaviest gate hooks I found are like 360#...?
What is reccomended to splice on to dyneema line..?
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #2 of 7 Old 03-14-2012
Re: Dyneema Lifeline Hooks
I would look at the New England ropes splicing guide. High tech line is usually fairly easy to splice.
New England Ropes - Splicing Guide
Good Luck
Schock - New York 36
Portsmouth, RI
mm2187 is offline
post #3 of 7 Old 03-14-2012
remetau's Avatar
What gate hooks are you looking at?
This is what I used:
Life Line Over Center Gate Hook With Splicing Eye
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #4 of 7 Old 03-14-2012 Thread Starter
Superior Sailor
Squidd's Avatar
So I don't need a $50 bend over hook, I can get by with a $10 SS snap clip...?
"Captin Ron"
Squidd is offline
post #5 of 7 Old 03-14-2012
poopdeckpappy's Avatar
Look into CS Johnson eyesplice life line hdwr
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #6 of 7 Old 03-14-2012
Zanshin's Avatar
The best splice for single braid Dyneema line is the Brummel Splice, I used it for the lifelines on my previous boat. It is extremely easy to do, can be re-set (with a bit of difficulty). I used the directions on Colligo Marine modified Brummel Splice with good success.
Zanshin is offline
post #7 of 7 Old 03-15-2012
DelmarRey's Avatar
I just used wire gates on mine. They hang better and don't get tangled with stuff when I come aboard. While the Dyneema life lines are always under a little tension and stay straight.
"Faithful are the Wounds of a Friend, but the Kisses of the Enemy are Deceitful!"
DelmarRey is offline
Dyneema lifelines AdamLein Gear & Maintenance 45 04-16-2012 10:00 PM
Reefing hooks Barquito Gear & Maintenance 9 01-03-2011 03:06 PM
Cockpit Line Hooks JDasson Beneteau 5 03-29-2010 11:55 AM
Dyneema eye splice bobmcgov Gear & Maintenance 16 03-07-2008 12:53 AM
Meat Hooks tenuki Gear & Maintenance 23 04-02-2007 11:24 PM
