My bottom is showing - SailNet Community
post #1 of 2 Old 03-14-2012 Thread Starter
One of None
deniseO30's Avatar
Red face My bottom is showing
because we didn't put the bottom paint on right away when we did the barrier coat, there are areas of the bottom where the ablative is flaking off. As I'm not in the mood to make myself look like Smurfette all over again. I'll scrape.. then... sand with 100 grit? Or look for somekind of epoxy primer? It seems to stay on the boat when it's wet, and only flakes off when it's power washed.
Good news; Barrier coat is very intact! No blisters after almost 3 years!
My last project!
deniseO30 is offline
post #2 of 2 Old 03-15-2012
Lake Superior Sailor's Avatar
Re: My bottom is showing
I had this same problem on my boat only I felt it was from mixing brands. Plan to sand mine with 100 Grit sandpaper, coat with a coat of barrier Pittit brand, & finish with Pittit brand Antifouling. Last fall the bottom looked great when I pulled it. After I powerwashed all the blue ran off.Hope this works for me, cause its expensive product & time consuming.
I want to get in the water by the 15th May as I am planning a trip to Isle Royal...Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
Battery showing charging when no charge applied labatt Gear & Maintenance 6 04-18-2009 01:57 AM
Leading edge of my rudder is showing its age ChicagoNewport27 Gear & Maintenance 14 04-22-2007 11:18 PM
Showing off the ship (The State) NewsReader News Feeds 0 07-23-2006 04:15 AM
