Chainplates- are these still o.k.? - SailNet Community
 7Likes
post #1 of 21 Old 03-14-2012 Thread Starter
Hookturn's Avatar
I took the upper shroud chainplates off my '71 Cat 22. It is clear that the eyebolts on all the shrouds have been leaking and I am in the process of replacing them. My question is whether I can still use the old chainplates or if they need to be replaced. Below are some pics. the first are taken right after I removed them. The next are pics of the worst one after I used some steel wool and a steel brush on it. It cleaned up really nicely, but I am concerned that I just made some cosmetic improvements and that they may still be subject to corrosion I can't see. Thanks for any help.
Hookturn is offline
post #2 of 21 Old 03-14-2012
Re: Chainplates- are these still o.k.?
In my opinion, No.
Don't get me wrong, I can't tell from your pictures if they have defects. But my point is that you've gone to the trouble to remove them. They were obviously old enough and corroded enough to cause you to be concerned about them. And lastly, they don't cost that much.
Replace them and sleep better at night.
Chainplates are perhaps the most important component of your standing rigging. Don't guess. Replace them.
knothead is offline
post #3 of 21 Old 03-14-2012
Closet Powerboater
MedSailor's Avatar
NO.
MedSailor
MedSailor is offline
post #4 of 21 Old 03-14-2012
benjmin's Avatar
This was ment to be a joke right?
I know someone would not use steel wool and a steel brush on stainless steel?
benjmin is offline
post #5 of 21 Old 03-14-2012 Thread Starter
Hookturn's Avatar
Thanks for your help! I will replace them.
StormBay likes this.
Hookturn is offline
post #6 of 21 Old 03-14-2012 Thread Starter
Hookturn's Avatar
Ben- I am a complete noob so I don't get the problem with using steel wool on stainless. Can you enlighten me? That will surely save me some embarrassment and problems in the future.
Hookturn is offline
post #7 of 21 Old 03-14-2012
mitiempo's Avatar
Anytime you use steel wool on a a boat you are adding small bits of steel to the chainplate or whatever you are polishing. If done on the boat the deck as well. These will rust very quickly leaving spots everywhere. Bronze wool is used sometimes and for polishing stainless there are varying grades of Scotchbrite available, to be done by hand or as pads for an angle grinder.
Brian
mitiempo is offline
post #8 of 21 Old 03-14-2012 Thread Starter
Hookturn's Avatar
I did this with the chainplates off the boat. But in any event will be replacing them per the advice above. So I guess it really isn't a problem of steel on stainless but a problem of using steel wool on anything and the corresponding rust. Is that right? If so, I get it. I thought there was some issue in particular with using steel wool on stainless. Thanks for the heads up!
Hookturn is offline
post #9 of 21 Old 03-14-2012
mitiempo's Avatar
The steel wool will also imbed microscopic bits of steel into the stainless that can cause discoloration and rust spots. One reason why stainless is polished without steel wool and electro-polished after the item is made.
Brian
mitiempo is offline
post #10 of 21 Old 03-15-2012 Thread Starter
Hookturn's Avatar
Ah got it. thanks for the heads up.
Hookturn is offline
Chainplates brokesailor Gear & Maintenance 24 04-08-2012 12:41 PM
Source for Chainplates CellNav Gear & Maintenance 2 01-03-2011 08:29 PM
Chainplates tager Gear & Maintenance 3 04-17-2009 01:53 PM
My Chainplates simple72 Gear & Maintenance 13 11-11-2006 08:19 PM
chainplates mary jewell Gear & Maintenance 1 10-25-2002 07:10 PM
