Old 11-18-2003
newsailor123 is on a distinguished road
Honda EU2000i
As far as generators to run A/C at mooring,
has anyone used a Honda EU200i ? Less than 50 lbs. seems it would be good on swim platform.
Old 11-18-2003
mcain is on a distinguished road
Honda EU2000i
Yeah. I''ve got a Honda eu2000i. Quiet, not too heavy, will run a medium sized (12K) air conditioner, if it is a newer, efficient model. Output is about 15 amps at 120V. Easiest way to connect it is to use a 15A to 30A (if you have a 30A connector on the boat) adapter, like a Marinco one. Then use it like shore power and charge batteries, etc. I like the feature that allows the gen set to spin down if there is not a big power requirement, which is possible because of its electronic inverter built in that maintains 60 hz and 120V, rather than other sets that need a constant 3600 rpm to maintain 60 hz.
It also has a small direct 12V output, probably designed to charge a small battery, but the wattage output of the 120V system is higher.
I haven''t used it long enough to judge corrosion in a salt environment. Others may have a comment on that.
Not bad for $860.
Old 11-18-2003
fly452 is on a distinguished road
Honda EU2000i
Thanks for the reply,The 200i is looking much better than a noisy $8000. genset.
Old 11-18-2003
obiec is on a distinguished road
Honda EU2000i
I just bought one, it dose run my AC and it will also run my hot water heater. I built a nice cover for it out of some sunbrella fabrick and it ataches nicley on my deck, durring good wheather.
Old 11-18-2003
tsenator is on a distinguished road
Honda EU2000i
obiec, what size and type of AC unit do you have?
Old 11-19-2003
Honda EU2000i
I got the 2000 because I just had to draw the line somewhere on boat stuff, and a diesel gen set was over the line. The internal gen set is bad enough to buy, but the installation is a pain and it takes a lot of room, weighs a lot, noisy, would kill access to the main engine, etc. I could buy a lot of 2000''s for the cost of an internal gen set.
I run my Mermaid 12k A/C with an oversized water pump just fine with the Honda 2000. Though I don''t intend to do it often. And I installed 3 separate CO detectors in the boat to make sure no exhaust gets into the boat.
I would strongly recommend the CO detectors whenever a gen set is running for whatever reason--there have been strange cases of exhaust being backwinded into portlights, hatches, vents, etc, and killing people. The "station wagon effect".
Old 11-27-2003
Honda EU2000i
My ac is just one of the portable hatch types, It cools the berth very nicly and helps on the rest of the cabin. about the CO problem. it is verry seriouse. We lost a couple from our dock last year. It was hot and thay took a nap on anchore. The problem was thay only had one CO detector and a fan was blowing acrost it, I guess thay will not give acurate redings whith wind blowing on them.
Honda outboard problems Variant_530 Gear & Maintenance 15 04-17-2012 09:27 AM
1981 Honda 9.9, 4 stroke o/b, Idle problem randj65 Gear & Maintenance 4 06-19-2002 10:59 AM
Honda 4 stroke outboard mikehoyt Gear & Maintenance 4 05-24-2002 05:08 AM
Honda Outboard Motor xenetia Gear & Maintenance 0 04-19-2001 02:50 PM
Honda Outboard GGartin Gear & Maintenance 0 01-14-2001 05:14 PM
