"Free" Snipe!!!!! - SailNet Community
 1Likes
  • 1 Post By overbored
post #1 of 6 Old 03-16-2012 Thread Starter
"Free" Snipe!!!!!
Hello,
I was recently given a "free" snipe that was taking on water and in need of repair. The PO gave me the title snipe, trailer and two sets of good sails/rigging so no complaints from me! I have begun making the repairs and have taken the deck off and flipped the hull over to get at the damage. First off let me say that I read where it should weigh about 380 lbs....not this one!!!!. I found the root of the extra weight the core material is a green foam that is VERY water laden, lol! It looks allot like the green stuff florist use for arrangement put I am sure it is different (I guess). I have cut out the shatter part of the hull and my Question is:
How can I dry out the core? Or can I?
It is inside so more water is not an issue. Also I do object to reglassing the bottom if a need to breech the skin somehow to get air flow in. As am atter of fact i would prefer it since the main reason I took on this boat was to get back in the swing of glassing before I start redoing the interior of a 22 foot sail boat we have purchased to restore. (I would rather mess up on the little one and do a better job on the big project). I used to do glass work for a job but not on boats..maily corvettes and hotrod projects...so cores are new to me. Any suggestions. Some pics are below of the core and damage.
Thx
Jason
jcase12 is offline
post #2 of 6 Old 03-16-2012 Thread Starter
Re: "Free" Snipe!!!!!
Sorry Guys I just realized that my title might make you think that I am giving away a Snipe. Sorry!
jcase12 is offline
post #3 of 6 Old 03-16-2012
Tartan 27' owner
CalebD's Avatar
Depending on the year of your 'free' Snipe there may not be any core at all.
Foam core material is a somewhat more recent development in the world of composites.
Nevertheless, dry out the hull as best you can: heat gun, hair dryer, acetone, fan, whatnot.
It looks like it is a pretty thin shelled hull so I see no need to try to repair it using any kind of foam core. Glass, epoxy and thickeners should get you there.
Good luck.
Everybody has one:
CalebD is online now
post #4 of 6 Old 03-17-2012 Thread Starter
Here is a pick with the damage removed I had to cut it out as it was crumbling in my hands so I just cleaned up the edge with a multitool. In the oner you can see how the core is used or at least what I am calling a core.
jcase12 is offline
post #5 of 6 Old 03-17-2012
overbored's Avatar
cut the inner skin and core about 1" bigger then the outer cut you made. Feather the inner and outer skin edges of the skin back about 2". epoxy in the new core material from the inside. glass both sides with the original thickness of glass fill and sand flush. good sorce for core material, glass and resin Composites from Aircraft Spruce
The core is PVC
DIVINYCELL FOAM PVC from Aircraft Spruce
a little cheeper but works well is Last a foam
http://www.aircraftspruce.com/catalo.../lastafoam.php
jcase12 likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 6 Old 03-17-2012
TQA
Bombay Explorer 44
TQA's Avatar
Some good examples of HOW TO here clicky
TQA is online now
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
"Oily Pollution" and "MARPOL Trash" Placards? SEMIJim Gear & Maintenance 16 11-15-2011 09:39 PM
S2 7.0 - free starboard "window" JBFoster S2 1 07-06-2010 12:36 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
