Another "Next Generation" anchor enters the market... - Page 14 - SailNet Community
 71Likes
post #131 of 291 Old 09-28-2012
Vendor
Mantus Anchors's Avatar
Re: Another "Next Generation" anchor enters the market...
Originally Posted by Marcel D View Post
I have one question when you guys are testing an anchor, does one ever get to use 1 to 10 scope? It seams all of the Mantus tests were using this method. Am I wrong I never get to use that kind of scope not even in clam bay. It is more like 4 to 1 and 5 to 1 and even then I seam to close to other boats.
Marcel its a very good question, the reason we use 10:1 is simply because that's what we usually use around here due to poor holding. Now all anchors were tested in equal environment, we are about post some more test videos and will include shorter scope pulls. What we try to show in the videos is that Mantus has a fast and reliable set. In the http://youtube.com/watch?v=BCEBOOnDcOU the bottom is so thick and viscouse that the Rocna and Manson Supreme don't set. So most people set out 10:1 to give it the best chance to bite.
Greg
Anchor Purveyor
Mantus Anchors is offline
post #132 of 291 Old 10-02-2012
Vendor
Hey S Netters! Just popping in to say... Mantus Hooks are finally here!
Greg
Anchor Purveyor
post #133 of 291 Old 10-19-2012
Vendor
Guys! SAILNET store is offering a new promo deal on Mantus Anchors.
Greg
Anchor Purveyor
post #134 of 291 Old 10-19-2012
Huck
smallboatlover's Avatar
i dont agree with that video at all. with those other anchors you should have chain thats what help set those anchors. just cause your doesn't require chain doesn't mean that the others dont need the chain. i think you guys should do a video testing with chain. Also maybe even do a power boat anchored and set the anchor and see if the powerboat can pull the anchor out. then id be sold on the anchor. even tho i might get the 2lbs mantus for my small sailboat.
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #135 of 291 Old 10-19-2012
Senior Moment Member
SloopJonB's Avatar
Read the whole thread - that was done.
SloopJonB is offline
post #136 of 291 Old 10-20-2012
Huck
o sorry didn't see it will look for it.
post #137 of 291 Old 10-20-2012
Huck
Im still not really convinced. you could stick with the old and faithfull that you know workes or go for some thing else that shows to work but you can't trust cause it's new. has mantus bin tested in hurricane force winds? ive seen other people use danforths the right 1 size over recomended size for huricannes and they didn't move a inch. I'm just not sold on this new type of anchor i have a plow and danforth and never had one pull even in 40mph winds. i just don't see the up side to this mantus anchor yet. I don't see what so diffrent from other anchor then fast setting.
post #138 of 291 Old 10-20-2012
SloopJonB's Avatar
The new Mantsocnas are more than just different. I have some experience with a hefty Rocna (not in hurricanes. ) and it is a definite improvement over older anchors - sets instantly, every time so far, never drags, resets instantly when veered out from swinging etc, never fouls, stores well on the bow roller. The roll bar makes a great grab handle if it needs to be adjusted in the roller to set a locking pin. Only downside I've seen is that it brings up 1/2 the bottom when hooked in mud.
I haven't used the Mantus but I'm sure it's the same, with the added advantage of breaking down to be stored flat.
Try one, you'll like it.
Mantus Anchors likes this.
post #139 of 291 Old 10-20-2012
Vendor
Huck the main reason we developed the Mantus, was in harder and or grassy bottoms traditional anchors often don't set or require extreme effort to set...
If in your neighbourhood your anchor sets all the time than there is no reason to switch. But bottoms vary and If you talk to cruisers that change ports frequently and never know what bottom they will encounter, an anchor that sets right away is paramount! In an emergency if you lose an engine and rocks are nearby than your anchor is the single line defence and needs to set immediately. So we optimized the Mantus for a quick and reliable set. This is what I am trying to relay in the video. You can use it with chain or no chain the point is, it will SET.
Oh and if you want to store an extra one you can because it breaks down....
Greg
Anchor Purveyor
post #140 of 291 Old 10-20-2012
Greg
I'm not seeing the deal???
GaryC5551 is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
"Buyer's Market" - any data to back it up? hazmat17 Boat Review and Purchase Forum 86 09-24-2012 09:25 AM
"Market Price" deniseO30 Chesapeake Bay 16 07-08-2011 06:43 PM
How to anchor with "stern-tie" single handed FishFinder Seamanship & Navigation 12 09-04-2009 12:37 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
