Another "Next Generation" anchor enters the market... - Page 20 - SailNet Community
 71Likes
post #191 of 291 Old 12-25-2013
chef2sail's Avatar
Re: Another "Next Generation" anchor enters the market...
Originally Posted by FranklinGray View Post
Paulo:
First of, I am the one who requested for the test to be done here in Bocas and it was my boat with me as the captain. I took the approach of this test as it was my responsibility to make sure the anchor set. I attempted to set each anchor the same way I set my anchor (more on that later). So NO, it was not an interested party. I have no vested interest how the Mantus performs but I do have a vested interest, as a cruiser, to know and inform others of what is the best anchor...aka...the reason for my request to test here as my primary anchor, the Bulwagga would "set" and hold like always but after diving on it I saw it didn't dig in like I am used to. I sent Greg a picture and asked if he thought his could do better.
Yes, I own a Mantus as a backup primary anchor but it is normally disassembled and stored. My Bulwagga is my primary because I really like it and I can't store it. That is, until Greg brought me a bracket to put it on.
Second, it may be uncharacteristic bottom for you, but not for people down here. Seems you fall into the trap many do like I used to in thinking everybody else's environment is like yours. Not so. I have been amazed at the different environments at each stop I make in my cruising.
Third, Each anchor was worked about the same as we could get. The process was: drop all anchors in the same spot...a few feet apart so they had a clean pull. Greg, the video guy would attach the chain and then let me know it was time to set it. If the wind was blowing hard enough at that time, I would instruct the helmsman to drift. If not, then I instructed to put in reverse at idle. Once the chain got tight, then I instructed the helmsman to start increasing the rpm slowly up to 2600 and then hold for 10 seconds or when I said to let off. In the case of the Spade, just like the Fortress (one of my anchors), we never got out of idle. I could tell when an anchor was dragging by the feel on the chain. I never gave the order to increase RPMs on those two.
It is true that it is not fair to test an aluminum Spade against a steal Mantus in setting but that's all we had to work with. We put out a request on the morning net and that is all we got.
The Mantus and Bulwagga performed about equal but because you can't buy a Bulwagga anymore, it is understandable that it's not part of the video. I know that the Mantus holds better due to me riding out a hurricane on each one, but I have to admit I was really impressed with the Mantus's setting ability in this stuff. I am still torn on what I think works better here in this hard stuff but one thing I am sure of, I can't go wrong with either one here or anyplace else.
Now if you doubt I am a real cruiser then you can just look up Bocas Del Toro on facebook and ask anybody on there if we did the test here and if Franklin on Dreamboat is really here. I'm not normally part of your web forum crew but I get on here to support the Mantus because I really wish everybody had a Mantus. In fact, one of the anchors we tested with I gave to another boat here so he would stop dragging. We had a small blow today and he didn't
Summary: Greg just hooked up the chain and video taped it while I tried to set it. I used the same scope, same boat, same chain and same process for every anchor. As a matter of fact, I didn't even know which anchor he was hooking up for each pull. I only found out after the pull. So no, you are wrong, it was an unbiased test.
Another shill from Mantus now appears. Actually we are quite used to Mantus commng up with their tedtimonials monthly on here to keep the anchor in the forefront. They are allowed after all as they are a financial supporter of Sailnet. Who will forget their first testimonial on here who never disclosed they were in actuality a member of the company.
Paulo is correct is saying your testimonial has as much weight as anoone elses who has an opinion and shouldnt be looked at with any more authority, Hihs point which I support that until these tests are done by an independent organization without any finanicial gain in an environement where the test is conducted and certified that all factors are controlled and equal to all the anchors, the videos are nothing more than sales propaganda for Manus.
In actuallity Mantus is a good achor I am sure with lines and build like the other two prominent new generation achors Manson Supreme and Rocna. It really is not a newly developed anchor as the design was tried and true before with Manson/ Rocna and I would expect the results when done independently will show NEGLIGABLE difference between the 3 anchors.
I dont know many sailors who have one of the two original anchors( Manson/ Rocna) scrapping them and rushing out buying a Mantus. I do see the usefullness of carrying a backup anchor, dissassembled like the Mantus to save space with the same design as the Rocna/ Manson.
I have had a ROCNA for 6 years now and stick by it as my primary with a Mantus in the anchor compartment dissassempled for use if necessary.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #192 of 291 Old 12-25-2013
"Shill"? Dude, a little heavy on the conspiracy theories.
Originally Posted by erps View Post
Smacky, what were your previous anchors for your comparisons?
I've only used the Danforth-styles in the past. But I've followed the anchor threads pretty closely over time - and had planned to go straight to a new gen anchor like the Mantus, Rocna, or MS when the time came. Rocna dropped off the list pretty quickly with their integrity meltdown. And I liked how Mantus was showing the videos of their tests. I was satisfied with them.
Then I saw MaineSail's evaluation of the "top three" - and his positive take on the Mantus.
That was good enough for me. I ordered one through SN.
THEN I received just about the best customer service on the planet. Since my arm was busted up from our accident, Greg himself delivered our new Mantus to the boat. Who does that these days?
So, despite Chef's aspersions above - I've got nothing but praise for Mantus. I think it would be very hard to go wrong with these guys the their gear.
smackdaddy is offline
post #193 of 291 Old 12-25-2013
The most female moderator
Donna_F's Avatar
Dock
Gentlemen, I know anchors are a hot topic right up there with politics and religion, but please keep civil.
One thing I don't understand and Paulo maybe you can help me. You said that you didn't understand why Mantus performed tests on their anchor since they are an "interested" party. I'm unclear as to whether you have a problem with them testing the anchor or the methods that they used. If it's the fact that they tested it, I'm really confused because why wouldn't any manufacture test their own product and continue to test to make sure that it behaves as it should? Otherwise, there'd be a heck of a lot of disbanded QA departments. If it's the location with that particular bottom that is the problem, I would hope that Mantus has done other tests in other circumstances and that this is but one of them. Since the Mantus posts says "we continue to test" than I'm going to assume they do.
I just want to be clear on your argument against it. Thanks!
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #194 of 291 Old 12-25-2013
Unless you have proof, Dave, I think that statement's gotta go....
Faster is online now
post #195 of 291 Old 12-25-2013
Maine Sail's Avatar
Wow, kind of rude...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #196 of 291 Old 12-25-2013
Donna_F's Avatar
Dock
Another shill from Mantus now appears. ...
This is a rather unfair assertion.
Yes, Mantus does post about their product. It's one of the benefits of supporting the site. Judging by the huge ad at the top of my page I think they still do support the site. I think, too, that members have benefited from the access to the company when they have questions and concerns as well as the periodic discounts Mantus extends to SailNet members.
I don't have a Mantus and for now, see no need to change my current two anchors. I do think that this type of communication on this site with other companies that our community uses would be a fine thing indeed.
So much happens in this forum and I don't remember anyone misrepresenting themselves. If I was interested in a new anchor, I'd probably be more clear on it as things like that I tend to remember if I'm interested in the company or its products. If that is the case, well, I think Mantus's open involvement and willingness to be an engaged member of our site since should be enough to let that incident remain in the past.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
post #197 of 291 Old 12-25-2013
blt2ski's Avatar
Not sure if they are deleted, but a person from Fortress has posted a time or two also. What I ahve noticed to a degree about both fortress and mantus, is they do point out the good, to a degree admit the bad.......all products have both good an dbad frankly. I have yet to trust, nor have I found something that is BEST ALL THE TIME! somewhere a condition arrives such that the thing, be it an anchor, truck, bobcat, lawn mower, shovel, rake....shoes.....anyway, it will not be the best!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #198 of 291 Old 12-25-2013
chef2sail's Avatar
Give me a break. a Difference of opinoin is now an aspersion???No asperations here...I purchased a Mantus long before you did...and yes I dont think they are the best thing since sliced bread...and yes my ROCNA from NZ still holds the promenent place at the end of my anchor roller while the Mantus sits dissassembled in the anchor locker to use if necessary.
I saw Mainesails evaluation and through it dont see where it determined that it was essentially anything better or different than a ROCNA or Manson.
So whats the problem mates.....anyone who disagree with Mantus boasts on here is not allowed to have an opinion or post it as strong as the people who shill for them? Even if you have bought their product like I did you cant have an opinion negative to them?
And oh yes Donna...you should return to the archives....when Mantus first posted here on of the posters did a piece extolling the vitrues of the anchor like she was this first time cruiser. Then it was determined she was in fact an employee of the company. I cant help that fact, but it is a fact and it soured me a little on the way the company did business. Maybe it is why I am so suspicious of their marketing or videos.
In spite of that I still purchased one. I guess that qualifies me to be able to speak about them more than someone who just reads about them and defends them blindly. But of course I would expect them to be defended as they are a SAILNET sponser. Its a shame ROCNA isnt.
Parkville, Maryland
Our blog-
post #199 of 291 Old 12-25-2013
chef2sail's Avatar
Yes so true. Go marketing scheme...Willing to spend money...willing to support the site...open invilvement and willingness to be engaged member.
Almost makes you think they are our friends here. They are here to make money...thats they reason they are so engaged. Bully for that...they are doing a good job at that.
Again I bought one...not because they were my friend...were engaged here...i bought it because i saw it the EQUAL of a Manson or ROCNA with the advantage that it could be carried dissassembled.
Nothing here has convinced me it is superior to the two original designs mentioned. Had I to the money to be only one, it would be the Manson or Rocna.
Parkville, Maryland
Our blog-
post #200 of 291 Old 12-25-2013
bljones's Avatar
SWMBO is working this evening, and I was feeling kinda melancholy about not being able to have a the traditional big family Christmas dinner until tomorrow...
..then I caught up on this thread. THIS feels like Christmas dinner! I'm just waiting for someone to throw down his napkin and stomp outside for a smoke.
"Mom always did like Mantus better!"
miatapaul, smackdaddy and jimgo like this.
It's 5 o'clock somewhere:
bljones is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
"Buyer's Market" - any data to back it up? hazmat17 Boat Review and Purchase Forum 86 09-24-2012 09:25 AM
"Market Price" deniseO30 Chesapeake Bay 16 07-08-2011 06:43 PM
How to anchor with "stern-tie" single handed FishFinder Seamanship & Navigation 12 09-04-2009 12:37 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
