Luft tape size - SailNet Community
post #1 of 3 Old 03-17-2012 Thread Starter
Luft tape size
I have a 30' hunter with a non- stock roller furling. I'm looking for a new or used genoa. The bead on the luft looks to be about 3/16". Is this a #6?
thanks for any help
riversteve is offline
post #2 of 3 Old 03-17-2012
Junior member, rest old
msmith10's Avatar
Re: Luft tape size
Luff tape size is measured in 32nds of an inch, I think. So #6 would be 6/32=3/16.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 3 Old 03-17-2012
Liquorice's Avatar
Re: Luft tape size
3/16" is a #6.
If you know what make and model your furler is, I can probably confirm the luff tape size.
sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
Does size matter?? Wheel size, that is... Undadar Gear & Maintenance 9 09-17-2011 07:39 PM
Slip size and boat size. rikbass Announcements and Suggestions Box 12 09-14-2010 02:52 PM
Where to buy Butyl Tape? sailak Gear & Maintenance 7 06-22-2009 10:27 AM
Blue Tape SailingFlorida Gear & Maintenance 22 10-23-2008 04:53 PM
sail size to boat size ronbrockman General Discussion (sailing related) 0 09-25-2001 04:10 PM
