mast step corrosion - SailNet Community
post #1 of 4 Old 03-17-2012 Thread Starter
mast step corrosion
My Pearson 28 , 1976 has a keel stepped mast which sits in water most of the time. Is there a way of preventing the aluminum mast from corroding other then keeping the area dry.
Thank you
Gary
gweiser is offline
post #2 of 4 Old 03-17-2012
jsaronson's Avatar
mast step corrosion
I had the same boat. The solution is to pull the mast cut off several inches and build a new step. It will cost 1500 to 2500 to have a rigger do it. Sorry!
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #3 of 4 Old 03-17-2012
Senior Moment Member
SloopJonB's Avatar
Re: mast step corrosion
Thank you. Gary
In a word, no. I've attached a couple of before & after photos of my own mast step to show how bad it can be if you don't take care of it. Incidentally, the mast was already out so it wasn't a very difficult or expensive job but it took quite a few hours to build the new step - epoxy composite with an aluminium step plate. Welding the cruciform locator was the only work I had to farm out.
Oh, as per JSAR, I had to trim 2" of corrosion off the bottom of the spar so built the new step 2" thicker to compensate.
SloopJonB is online now
post #4 of 4 Old 03-17-2012
Never had an aluminum mast but the engineering is relatively simple methinks. Could you slack the turnbuckles and jack up the mast by.the mast winches or boom fitting and support the weight on a structure on deck while you cut off what's corroded on the hoof and build up whats needed in the bilge to take the weight when done .I'd envision an A frame with a comealong to a rolling hitch on the mast for control but positive blocking while you've got your fingers under it. Measure twice, cut once..
Capt Len is offline
Mast Step Corrosion follysurf Gear & Maintenance 21 02-10-2012 08:52 PM
mast corrosion - how serious? pic attached tominny Gear & Maintenance 9 01-05-2012 03:35 PM
Is there a step by step for a stepping of the mast? Skipper Joe Gear & Maintenance 5 07-15-2009 07:45 PM
Mast Corrosion? greencaptn Gear & Maintenance 3 07-09-2007 04:11 PM
Mast Corrosion Repair oldguyflier Gear & Maintenance 5 04-15-2007 11:06 PM
