what size genoa for hunter 30 T - SailNet Community
post #1 of 4 Old 03-18-2012 Thread Starter
I realized my last post looked like an ad.
I have an 100 jib, roller furling on my 30T I think the main is more the primary sail on this boat, but i would like a larger headsail for general use I'm thinking of a 150, Any suggestions?
riversteve is offline
post #2 of 4 Old 03-18-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: what size genoa for hunter 30 T
OK if you do most of your sailing in winds around 10 knots.
Why not keep your current jib and add a code zero on a furler in front of it!
TQA is offline
post #3 of 4 Old 03-18-2012 Thread Starter
realiy apreciate the advice, thanks
post #4 of 4 Old 03-18-2012
blt2ski's Avatar
Your other thread a person mentioned a 123-135 or there abouts. That also is not a bad size. BUT, as mentioned, depends upon the where you sail as far as ave winds. If in the salish sea as I am, a 140-155 is pretty nice to have, then a 110 for the windier days.
It will also depend upon if you are mainsail driven rig as I think many hunters are, vs a genoa driven masthead rig like mine.
I also have a mini forstay, when flying anything over about a 135 or there abouts, one needs someone up front to guide the sail around or it will get stuck, get banged up etc going around said stay. If it is my daughter and I, no big. She goes forward, I can steer and pull the genoa sheets in. If it is my wife and I, we're lucky if she gets the boat tacked/steered much less pull any jib sheets in. SO it is me pulling, if the genoa gets stuck, go forward, back pull in, forward to foot the foot over the life lines, back to tighten the jib more.......My 140 should have been a 130 or there abouts. Did not realize this when I switched from the original worn out dacron 135 to a mylar based 140 which is stiffer than dacron, a bit longer.....I will not use my 155 string sail with wife on board needles to say.
The how big will and should depend upon many things frankly.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
How to determine Genoa Size EJO Gear & Maintenance 29 10-09-2016 10:53 PM
genoa for 30T Hunter riversteve Gear & Maintenance 1 03-18-2012 11:32 AM
Bunge size for Genoa slides billdre Gear & Maintenance 5 01-08-2011 11:18 AM
Slip size and boat size. rikbass Announcements and Suggestions Box 12 09-14-2010 02:52 PM
Mid size Hunter dpierce Boat Review and Purchase Forum 8 08-23-2001 11:32 AM
