Non-skid worn down to fiberglass - Page 2 - SailNet Community
post #11 of 12 Old 04-03-2012
72 C&C Corvette
CorvetteGuy's Avatar
Re: Non-skid worn down to fiberglass
So there must not be much hardware considering your problem is on the non skid, clean the area, tape it off and put a coat of Kiwi grip on it, quick, easy and fairly inexpensive. Would recomend this product. Used it on all non skid topside of my 32' and am very pleased
CorvetteGuy is offline
post #12 of 12 Old 04-03-2012
It is hard to tell from the pictures if the fiberglass that you see is the layup for the deck or some sort of a backing for the nonskid. I am thinking maybe they used prefab sheets to redo the nonskid at some point, I would not be surprised if there is gelcoat under those fibers. If that is the case, the issue is purely cosmetic. Even if the exposed fibers are part of the deck pay up, you should be able to seal with with a new coat of nonskid paint as suggested.
meteuz is offline
Tags
buying , catalina 30 , repair , topsides
Rudder bushing worn out (F-24 Mk1) brak Gear & Maintenance 0 11-12-2010 07:35 PM
Worn Companionway Cover harbin2 Islander 5 10-07-2009 08:51 PM
How to remove fiberglass resin from non-skid deck traumadoc Gear & Maintenance 3 08-29-2009 09:57 PM
Worn Cutlass Bearing Advice TSPMorgan383 Gear & Maintenance 6 05-14-2009 10:45 AM
A Worn Shaft Log Tom Wood Gear and Maintenance Articles 0 10-06-1999 09:00 PM
