Non-skid worn down to fiberglass - SailNet Community
post #1 of 12 Old 03-18-2012 Thread Starter
I'm looking to buy a '78 Catalina 30 that appears to have some issues with the non-skid. I'm trying to get an idea of how extensive the fix may be. Is it a basic new non-skid application or even more significant top-side work?
Has anyone seen something like this and can offer some advice?
Don't want to pay for a survey if this is a show-stopper right here.
Although the boat is a bargain, don't want to get myself into a money pit.
Some picture...the yellow/gold area is the non-skid:
sfbaysailor2012 is offline
post #2 of 12 Old 03-18-2012
Bristol 45.5 - AiniA
Re: Non-skid worn down to fiberglass
Essentially what you would need to do is paint these areas with a suitable finish (eg Kiwi Grip?) or with paint with an anti-skid compound added. Fair bit of work, especially if there is much hardware to remove, but not a high-skill job or very costly.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #3 of 12 Old 03-18-2012
jsaronson's Avatar
Practical Sailor reviewed the non skid paints last year. It is. dIY project.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #4 of 12 Old 03-18-2012
mitiempo's Avatar
Strange that there is not any gelcoat under the non skid - which looks like paint. You can see the mat underneath, especially in the last pic.
Brian
mitiempo is offline
post #5 of 12 Old 03-18-2012
Looks like somebody ground it down... or used a holystone on the deck
garyguss is offline
post #6 of 12 Old 03-18-2012
I think I'd roll on a coat of gelcoat to seal it then use Kiwigrip or Duraback to coat it
garyguss is offline
post #7 of 12 Old 03-19-2012
TQA
Bombay Explorer 44
TQA's Avatar
2 - 3 coats of epoxy plus two coats of nonskid deck paint will do a good job.
2 -2 coats of exterior grade enamel paint with sand mixed in will be almost as good.
TQA is offline
post #8 of 12 Old 04-02-2012 Thread Starter
Thanks for the tips!
post #9 of 12 Old 04-03-2012
poopdeckpappy's Avatar
I would prime with a high build, fair it, prime with high build again, then a epoxy prime with silica sand broadcasted ( heavy ) over the epoxy primer; once that has gone off, remove excess silica, at that point you'll have a nice even non skid. Now you apply your finish ( at least 2 coats ) of whatever finish color you want
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #10 of 12 Old 04-03-2012
doicus's Avatar
I know I will get some negative feedback on this but here go's I re-finished my non-skid on my 32 Fuji with a good quality porch and deck paint with non-skid that I added to the paint just before applying. All from lowe's total price 30 bucks. Two year's and it looks good !
doicus is offline
Tags
buying , catalina 30 , repair , topsides
Rudder bushing worn out (F-24 Mk1) brak Gear & Maintenance 0 11-12-2010 07:35 PM
Worn Companionway Cover harbin2 Islander 5 10-07-2009 08:51 PM
How to remove fiberglass resin from non-skid deck traumadoc Gear & Maintenance 3 08-29-2009 09:57 PM
Worn Cutlass Bearing Advice TSPMorgan383 Gear & Maintenance 6 05-14-2009 10:45 AM
A Worn Shaft Log Tom Wood Gear and Maintenance Articles 0 10-06-1999 09:00 PM
