Which line absorbs the most force? - SailNet Community
post #1 of 13 Old 03-18-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
A spring/summer project I may do this year is to replace my anchor's snubber. The previous owner fabricated a nice strong attachment point at the stem waterline where the bobstay attaches. He had some double braid line (nylon or poly, I can't tell for sure) spliced to it for a snubber/bridle.
I'd like to replace it with something more stretchy to help avoid shock loads from the anchor in a major blow. Which line is best for absorbing shock, or more accurately, distributing the load over time?
Nylon or polyester 3strand?
Nylon double braid?
6 or 8 plat poly or nylon?
Something else?
The line will be about 12feet long and I'll also put a rubber dock snubber or loops of shock-cord in line on the line itself.
MedSailor
MedSailor is offline
post #2 of 13 Old 03-18-2012
Gary M's Avatar
Re: Which line absorbs the most force?
For an application such as yours polyester basically does not stretch, 3 strand nylon would be your best bet. However with such a short piece of line you will not get a lot. The rubber snubber will be more useful.
Gary M is offline
post #3 of 13 Old 03-18-2012
pdqaltair's Avatar
As stated, 12 feet won't get you a lot. If the notion is to absorb the impact of waves, then I would think you need 3-4 feet of stretch at working loads. While at high load nylon stretches as much as 30% before failure, you probably want to work in the 10% range, meaning 30 feet is better.
I have a 16-foot bridle, and since I changed to all chain I've noticed it doesn't do much for waves if it's rough; the chain gets straight and it jerks. I have a 60-foot bridle to use when in an exposed spot. I part, this is because I generally am in shallow water without much chain out.
Definitely nylon. Technically 3-strand stretches a little more than braid; in fact, the core of climbing ropes is laid (50% right hand, 50% left hand, to prevent spinning and internal hockling), not braided, for that reason. But double braid will work fine, you just need a bit more.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #4 of 13 Old 03-18-2012
Courtney the Dancer
jrd22's Avatar
Three strand nylon.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 13 Old 03-18-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
What about plaited line? *plait or 6 plait. How does it compare to 3 strand?
MedSailor
post #6 of 13 Old 03-19-2012
TQA
Bombay Explorer 44
TQA's Avatar
3 strand nylon and you might want two set ups. One that is about 3 feet over the bow for normal everyday use, this can be a little thinner.
The second one is for storms and should be 20 - 30 feet over the bow and heavier.
TQA is offline
post #7 of 13 Old 03-19-2012
jackdale's Avatar
From my experience 3 strand nylon is the way to go. I have conducted no tests.
Just use a rolling hitch around the chain and feed it over the bow roller to a cleat. A bridle is a little fussy for me.
jackdale is online now
post #8 of 13 Old 03-19-2012
St Anna's Avatar
I would agree entirely with this, although my longer one is about 18' only; and the shorter one is about 5' off the bow.
I attach them through a shackle under the bow roller so there is zero chafe, zero noise. Just check the shackle now and then.
Best advice though from TQA
St Anna is offline
post #9 of 13 Old 03-19-2012
Senior Slacker
SlowButSteady's Avatar
I might add that a good length of chain also helps absorb shocks. I realize this is somewhat counterintuitive, however, the weight of the chain causes it to resist lifting up off of the bottom and/or stretching straight. The bow in the chain acts to absorb much of the shock, both because it takes a lot of force to straighten a chain rode and because if the fluid dynamic resistance as it moves through the water. Adding a good-sized weight (i.e., a kellet) to the rode enhances the effect.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #10 of 13 Old 03-20-2012
Med, AFAIK 3-strand has the most stretch, which is why it IS preferred for dock and anchor lines. It is very much line a torsion bar, as you pull the strands untwist, yielding to the load. Then they come back, tightening again. To get more shock absorption, you woul dneed a real snubber (heavy "rubber" section) or improvise with a small auto coil spring from a junkyard, in something like a PVC pipe sleeve to hide it and make it pretty.
hellosailor is offline
Should I buy a Force 5? dndrich Boat Review and Purchase Forum 29 08-13-2008 01:56 AM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 02:38 PM
Shorter Single Line Reef Line dnseal Gear & Maintenance 6 11-26-2006 06:58 PM
air force sails shmangasarian Gear & Maintenance 1 05-25-2005 07:15 PM
Hudson Force 50 leonsk Boat Review and Purchase Forum 0 10-04-2000 02:12 PM
