Teak Deck Treatments - The Best ? - Page 3 - SailNet Community
View Poll Results: Which is the best teak treatment ?
Teak Wonder 0 0%
Semco 8 50.00%
TeakGuard 1 6.25%
Cetol 5 31.25%
Other 3 18.75%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
 3Likes
post #21 of 28 Old 03-26-2012
RichH's Avatar
Re: Teak Deck Treatments - The Best ?
... not any more than a textured non-slip FRG deck.
Besides, decks on a 'sailboat' are set to the approximate gentle curving shear line (higher in the bow and stern than at midships) which quickly shed water to the amidships scuppers .... unless one has a 'clorox bottle' or 'euro-style' with no shear.
RichH is offline
post #22 of 28 Old 03-26-2012
Moderator
Jeff_H's Avatar
To me the absolute best way to treat teak decks is to remove the teak, epoxy over the sub-deck and put down KiwiGrip deck paint. Anti-skid Boat Decks from Pachena LLC - KiwiGrip anti-slip deck coating
Its cooler, grippier and a lot less maintenance.
Jeff_H is offline
post #23 of 28 Old 03-26-2012
Originally Posted by RichH View Post
... not any more than a textured non-slip FRG .....
But you can scrub a non-skid with a brush to get into the crevices.
A teak deck should only be scrubbed with a scotch bright, which would float over the proud caulking. Maybe, if you seal teak, you can hit it with a brush. But that still feels like you could raise the grain, unless your sealant really paints it over.
Jeanneau 54DS
Minnewaska is offline
post #24 of 28 Old 03-26-2012 Thread Starter
OK - Might try to get a sample of clear and natural to get a better idea. Wiping the caulking sounds a bit of a chore, so Clear might be the place to start - we can always go Natural or darker, but I suspect we will prefer more frequent applications. Time and personal experience will tell. I am wondering how long it takes per coat for a 50' yacht such as an Oceanis 50. I would imagine the cockpit area and transom step would be around half an hour, but the deck would be a wild guess at 3 hours ???
David B is offline
post #25 of 28 Old 03-27-2012
As for application time, we tape first and do two - three coats. We only have the cockpit and toe-rails -- no deck -- and the total is about three hours on a Beneteau First 36.7.
If we first use Teak Prep, we tape and apply the Teak Prep late one day and apply the Semco the nest day.
TejasSailer is offline
post #26 of 28 Old 03-27-2012 Thread Starter
Thanks. I was forgetting about the toe rails - a bit more fiddly !
David B is offline
post #27 of 28 Old 03-27-2012
RichH's Avatar
FWIW - I have a 'teakey' and it takes ~1/2 hour to 'slop on' a coat of SEMCO to the decks, anchor grate platform, cockpit seating and cockpit grates, I dont 'mask' and wipe up any 'drips' with a solvent loaded rag.
As far as deck scrubbing, you can use a stiff scrubbing brush on a concours quality automotive paint job too. For my decks I use an ultra soft bristle brush on a long pole and use pH neutral car wash soap - you just have wait a bit until the soap does the emulsifying and softening of the dirt.
I know sports fishing boats that use ScotchBright pads and bleach to clean the teak ... every damn time they get back to the harbor ..... and they entirely replace the teak every few years.
RichH is offline
post #28 of 28 Old 03-27-2012 Thread Starter
Half an hour - now that sounds encouraging ! Watched a video yesterday (they were applying teak oil to a deck) where they were using a pad on the end of a long handle (like a floor sponge). It made the job look a whole lot easier, so I think the process will be to do the diddly bits, then wipe over with the pad arrangement - might even be enjoyable !. I must say, seeing that rich teak colour convinved me that a protective coating is the way to go.
Scrubbing - yes, I have already ordered the softest of brushes. I don't want to be scrubbing away the soft parts of the wood and leaving tramlines. I gues another plus for the coatings - they must have some densifying and protective advantage for the soft parts, even though the natural teak oils prevent penetration to any extent
Thanks,
David
David B is offline
Tags
deck , teak , treatment
Teak Deck Removal petermac Gear & Maintenance 7 01-10-2008 02:13 PM
Teak deck companies....who's best Talisman66 Gear & Maintenance 8 09-11-2007 05:02 PM
Teak Deck - Finish It or NOT? EmeraldLady Gear & Maintenance 1 10-07-2005 07:27 PM
Surface Treatments andiamod11 Gear & Maintenance 1 02-27-2004 02:10 PM
Teak deck Q ekhar Gear & Maintenance 8 03-10-2002 05:48 PM
