Universal 5411 engine mount replacement - SailNet Community
post #1 of 4 Old 03-19-2012 Thread Starter
I have a 1983 5411 (M-15) Universal Diesel that tends to vibrate a bit at high speed under load. I've had a mechanic realign the engine and that helped a little but he says unless the engine mounts are replaced no further alignment adjustments can be made. Has anyone here done an engine mount replacement on this engine? Can just the rubber cushions in the mounts be replaced? Do you have to pull out the engine to do the job or can you somehow replace the mounts one at a time with the engine still basically in place? (And then, of course, realign the engine.) Thanks in advance for any info on this kind of project.
imiloa is offline
post #2 of 4 Old 03-19-2012
Lightbulb Re: Universal 5411 engine mount replacement
The rubber part of the mount is bonded to the steel parts with the stud attached. You will need to replace the complete mount.
Once they get old, and "old" means over 15 or 20 years, the rubber can compress down and collapse, and if not that it will harden from aging of the rubber compound and lose its ability to attenuate vibration. Depending on the installation, some engine installations will have allowed sea water to attack the steel or fuel oil to attack the rubber.
Buy new mounts as a set. Your Ericson will likely need three if the Universal has the single front mount. Note that, depending on the balance point of the engine, the weight specification may be different for the real mounts than for the front.
I replaced all of our mounts (M25XP Universal) a few years ago when I looked really closely and found that one on our rear mounts was collapsed down to where metal was bearing on metal. Hard to see with the typical small-boat engine installation where you might need a mirror-on-a-stick to even see it closely.
Our mounts were replaced without pulling the engine. Usually the engine can be raised up, one side at a time, and the new mount slipped in. Check to see if the lag screws into the frp mountings will still allow you to torque 'em up tight. We find that even with relatively good access on our boat, it takes several different wrenches and sockets and precision swear words to do this job.
New mounts can be sourced from Univeral/Westerbeke or from independant sources like PYI.
Please also report on your questions, answers, and progress over at the owners' site at EricsonYachts.org: The Starting Point on Ericson Yachts!. Pictures are a great help.
Cheers,
Loren
EY.org moderator
olson34 is offline
post #3 of 4 Old 03-19-2012
JimsCAL's Avatar
Lived with a 5411 for 20 years. It was always a pretty smooth running engine (for a 2 cylinder). Yes you can change the mounts without pulling the engine. But its not clear to me that the cause of the vibration is necessarily the mounts. Could be something else like an out of balance propeller. Make sure the mounts are what's causing it before spending a lot of money changing them.
JimsCAL is offline
post #4 of 4 Old 03-20-2012 Thread Starter
JimsCal, This is not a huge problem - I just don't want it to turn into one. The engine itself does run smoothly and I recently had the cutless bearing replaced, the strut remounted and the prop serviced/balanced as well as having the engine aligned. None of that was done to directly address the vibration - the bearing showed signs of wear, the strut had a minute amount of play in it, and since I was at it I figured I might as well make sure the prop was balanced. The mounts are originals from 1983 and given the mechanic's comments and the vibration at high speed plus some of the things I've read on line I'm thinking it's just time to replace them.
imiloa is offline
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 12:54 PM
Universal 5411 gbertelsen Gear & Maintenance 2 05-12-2009 11:56 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 08:16 PM
Universal 5411 exhaust elbow cooltec Gear & Maintenance 2 06-25-2007 07:20 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 07:01 AM
