rudder delam and bondo under the waterline... refit almost done - SailNet Community
post #1 of 4 Old 03-19-2012 Thread Starter
Well I took my Hunter 25 out of the water two weekends ago.
Turns out I had about 100 blisters. I ground them out, and put a few layers of glass cloth in the ground out area. I then filled with epoxy and filler. However, after drying the filler shrunk a bit and still left an approximately 1/8 inch depression. My father showed up with some automotive Bondo filler, and filled the depressions before I could say "that's not marine grade!". Well, it's there now, under my new bottom paint. Is it gonna fall out? I am confident that the epoxy underneath will hold, but I am worried I will have sloughs of my bottom paint just fall off with the bondo under it...
The other, related issue I had was with the rudder. After grinding what appeared to be a blister, the wet part just kept getting deeper. I finally got down to the steel:
It appears that water go into the rudder itself, and was trapped between the steel and the laminate of the rudder. I got as much water as possible out with the grinder, let it dry overnight, hit it with a heat gun, and glassed/filled it in with many layers of glass and a healthy amount of filler too in all the crevices. The rudder is solid, but there is a thin layer of rust between the steel and the laminate. The laminate doesn't seem securely attached to the steel, but somehow there is no play at all in the rudder... Is this a long term problem? Did I "fix" it? I didn't cut out all of the wet/rusty stuff, probably less than half, because any more and I would have had to build a new rudder. Anyone else had this problem?
peterchech is offline
post #2 of 4 Old 03-19-2012
One of None
deniseO30's Avatar
Re: rudder delam and bondo under the waterline... refit almost done
Drill holes in the bottom set in the sun for a week or two. Remove all the paint, Bondo may not "stick" to epoxy. At least give the whole rudder a few coats of epoxy or epoxy barrier coat would be my suggestion. In the future, use epoxy filler instead of Bondo (bondo is not an epoxy it's polyester, (hope I'm wrong)
The steel needs to be under FG cloth that is properly wrapped around the whole runner. But don't do that if it's not dry.
Fair winds!
My last project!
deniseO30 is offline
post #3 of 4 Old 03-19-2012
The 'bondo' may absorb water and need redoing on the next haulout.. keep an eye on it, but it does look like your rudder needs a real total dry out and inspection, and proper rebuild.
Faster is offline
post #4 of 4 Old 03-19-2012
Senior Moment Member
SloopJonB's Avatar
Denise has it right - cover the Bondo with epoxy or it will absorb water. Make your own epoxy fillers for underwater use. I do it for ALL boat filler situations.
SloopJonB is offline
Moisture delam at through hulls jb1528 Bristol 6 06-25-2012 02:22 PM
centerboard repair using bondo priceless9192 Gear & Maintenance 7 12-20-2011 08:16 PM
Genoa Delam Wooes Sabreman Gear & Maintenance 9 10-31-2010 09:54 PM
Bondo Glass??? 4cylindersoffury Gear & Maintenance 24 09-05-2010 04:49 PM
how is bondo for boats? Captain_Rick General Discussion (sailing related) 8 03-26-2007 06:51 PM
