Pulling new wire for cabin lights - SailNet Community
 2Likes
  • 2 Post By Lake Superior Sailor
post #1 of 5 Old 03-20-2012 Thread Starter
While replacing the cabin lights in my 82 Cal 2-25 I noticed the factory wire has a nice black color at the ends. There is not enough wire sticking out of the liner to cut till I find clean wire so it looks as though replacing the wire is my next option. I am thinking of soldering and taping the new wire to the old and pulling it through. The lights are all daisy chained together so the longest pull is about 5 feet, but I have no idea what is up there.
Has anyone successfully done this?
Catalina 25
tpothen is offline
post #2 of 5 Old 03-20-2012
Lake Superior Sailor's Avatar
Re: Pulling new wire for cabin lights
Do not solder, use marine crimps instead. Use tinned marine wire if you want it to last. I changed a lot of wires on my Cal 28 not that hard! I had to add a fuse box as mine was built before those where thought needed.....Dale
chef2sail and mitiempo like this.
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 5 Old 03-20-2012 Thread Starter
I'm using tinned wire and adhesive lined crimp terminals for everything. The soldering is just to pull the new wire through using the old wire. A crimp here would be to big to fit through the wire exits in the head liner.
Catalina 25
tpothen is offline
post #4 of 5 Old 03-21-2012
Sounds like a reasonable plan to get the new wire through. That's how I do it.
Consider using 2 core (red and yellow) 16 gauge cable with a white sheath, should say "boat cable" on it. This meets the latest codes. The white sheath gives some extra protection against chafe.
MarkSF is offline
post #5 of 5 Old 03-21-2012
nickmerc's Avatar
I ended up just using electrical tape to join the old and new wires for pulling. It worked fine. before you start pulling see what you can take apart to get access to the wire ways. I found out after I finished squeezing into a really small space that I could just have removed my stove and had easy access to the worst part of the wire run. Live and learn.
nickmerc is offline
Best CFL or LED cabin lights? bwindrope Gear & Maintenance 34 02-17-2010 09:15 AM
Suppliers for flooring adn cabin lights impromptu38 Beneteau 0 01-12-2009 08:16 PM
Wiring cabin lights in Serial maccauley123 Gear & Maintenance 59 02-28-2008 05:01 AM
Original Morgan Cabin Lights pwerndli Morgan 1 12-20-2007 05:02 PM
ABI LED Lights - NO tinned wire paulmcquillan Gear & Maintenance 0 06-20-2005 07:37 PM
