Right tiller pilot for a 1996 Hunter 26 - SailNet Community
post #1 of 7 Old 03-20-2012 Thread Starter
Sailing alone it's tough getting myself a cold drink or fix myself a bite to eat.
Right now I have a line that has a clamp fixed to the tiller that is ok in calm seas. I'm thinking a tiller pilot is the next step in what I need.
Do they require a connection to a navigation chart plotter or is this function self contained in the tiller pilot?
My boat's fitted with a Lowrance chart plotter that bought within in the last year. Wish I'd known about a touch screen back then. The key input is archaic.
I don't want to have to replace the Lowrance if I don't have to for a tiller pilot if in fact I need the two in compliance.
suggestions?
chiriqui is offline
post #2 of 7 Old 03-20-2012
Lake Superior Sailor's Avatar
Re: Right tiller pilot for a 1996 Hunter 26
Tiller pilot stands alone Has built in compass reads present direction and maintains it. I have the small Raymarine on mine ,works ok with sail, but will screw up when motoring. Just need power hooked to it..........Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 7 Old 03-20-2012 Thread Starter
ah.. ok.... good so I just find the one that is a good fit for my boat.
You say it messes with motoring. They can't hold a course under power or what they get in the way. They detach right, without much fuss? Or are you saying in heavy seas under power they can't hold a course.
chiriqui is offline
post #4 of 7 Old 03-20-2012
My Yanmar YMS 8 seems to throw off the compass when running. The motor is directly under the tiller pilot. You might check Ebay thats where I got mine....Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
post #5 of 7 Old 03-21-2012
Barquito
Barquito's Avatar
Tiller pilots hold a compass course. They usually have a tacking feature, so it will steer through a tack while you tend to lines. Some can communicate with electronics to steer a wind course. Remember, if you are alone onboard with the tiller pilot engaged, the boat will keep sailing if you fall overboard.
Barquito is offline
post #6 of 7 Old 03-21-2012
nickmerc's Avatar
I have the Raymarine 2000 for my Pearson 30. The literature said the 1000 would work, but I wanted the bigger one so it would have the power to hold coarse in heavier winds and swells, as well as last longer.
nickmerc is offline
post #7 of 7 Old 03-21-2012
Senior Slacker
SlowButSteady's Avatar
Simrad TP10 - nothing fancy, self-contained, simple to operate, designed for exactly your sort of application. It will follow a compass course, tack on command, and has some ability to compensate for sea-state effects. About $400.
I have an earlier version on my Cal 227. The only trouble it's ever given me is when the power plug needed tightening (not really a problem with the unit, per se).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Which Tiller Pilot Flybyknight Gear & Maintenance 13 09-26-2011 11:58 AM
Advice for repair of tiller pilot->tiller connection jgsteven Gear & Maintenance 2 09-11-2009 04:53 PM
Which tiller pilot to buy? jgsteven Gear & Maintenance 8 03-27-2009 08:11 PM
1996 hunter 336 Izz Boat Review and Purchase Forum 3 07-18-2007 08:51 PM
1996 Hunter 40.5 moorings101 Boat Review and Purchase Forum 5 01-20-2007 11:28 PM
