Side paint - Page 2 - SailNet Community
 10Likes
post #11 of 30 Old 03-23-2012
Re: Side paint
Originally Posted by BreakAwayFL View Post
Also, yes, it's the outside of the hull above the waterline. The topside could probably use some paint, but it's not that bad as is.
Thanks!
BA... the outside of the hull above the waterline IS the 'topsides'... what you're calling the topsides is the deck. And to continue the confusing terminology, know that the inside surfaces of the hull above the waterline is the "ceiling" and the underside of the deck/cabin is the 'overhead'...
Faster is offline
post #12 of 30 Old 03-23-2012
johnnyquest37's Avatar
Re: Side paint
Have you considered waxing and polishing the topsides?
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #13 of 30 Old 03-23-2012 Thread Starter
BreakAwayFL's Avatar
Re: Side paint
I had thought about it but since it's chalking, to my novice eyes, it seemed perhaps too far gone. I'm certainly open to giving it a shot first, as it would cost a thousand times less.
I had looked at a one stage wax/polish, and then if it showed significant improvement I would go ahead with the work of a two stage.
And WOW i need to get a hold of this terminology! So yes, the topsides are what I'm talking about, the deck is fair and doesn't need too much attention at this time, just a good scrubbing (I have a separate thread trying to find soaps safe to use while in the water.)
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
BreakAwayFL is offline
post #14 of 30 Old 03-23-2012
Re: Side paint
Waxing is probably temporary at best, if it's chalking. I would try to machine compound it, if my fallback plan was to paint. A bad compound job could force you to paint. But, it may be worth the effort to potentially avoid needing to.
Jeanneau 54DS
Minnewaska is offline
post #15 of 30 Old 03-23-2012 Thread Starter
Side paint
I just picked up StarBrite wash/wax as a first step. The 2 step would be the compound wax then polish. Let's see how clean she gets after some scrubbing first. I'll report back.
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
post #16 of 30 Old 03-23-2012
mitiempo's Avatar
Re: Side paint
BreakAway
This might help Tips For Compound, Polish & Wax
You have to remove the oxidation before you polish and wax.
Brian
mitiempo is online now
post #17 of 30 Old 03-23-2012
bljones's Avatar
Re: Side paint
And yet, leaving the cabin and going on deck is often called "going topsides" and a popular brand of DECK shoes are "topsiders" so I can understand the confusion.
What we really need is a sticky: "Newbie's salty glossary: Read first!" , with all of the most essential terminology to be able to communicate on sailnet, and the dock, passably intelligently.
BreakAwayFL likes this.
It's 5 o'clock somewhere:
bljones is offline
post #18 of 30 Old 03-26-2012 Thread Starter
Re: Side paint
So, yesterday I was in the water hand washing the boat, getting to know every inch of her. I have come to the conclusion that A: she needs a bottom job ASAP. and B: she really could use a sanding and a new coat of gel on the topsides and C: the striping needs to be stripped and repainted, as it's peeling, and the color under it is peeling as well.
Crap.
I'm going to do it myself, and I'll be following that wonderful thread posted in this thread as my how to guide.
Now comes the search for affordable (LOL right) gel and bottom paint, and figuring out the costs of having her pulled from the water and set up in a DIY yard.
Could anyone contribute what the haul out and monthly fees in a DIY yard might be? Also, are there any "hidden" charges these yards like to stick people with?
Thanks all.
Nelson Abreu
Serenity Now
Coronado 25
Insanity Later
Walker Bay Dingy
post #19 of 30 Old 03-26-2012
Re: Side paint
Are you really planning to redo the gelcoat? That's a nightmare and not a great DIY job. At worst, I thought you would sand her down, fair in filler, prime and paint.
Don't be penny wise and pound foolish with the bottom paint. Get one that works well in your area. The effectiveness of bottom paint is very regional. The cost savings for the cheapest paint will come back in the form of hull cleaning or more frequent application.
mitiempo likes this.
Jeanneau 54DS
post #20 of 30 Old 03-26-2012
Re: Side paint
p.s. if you're committed to painting, a small area with compound (not wax) is worth trying. If it comes out well, younwill save yourself a ton of grief. If not, you're back to painting.
The cove and boot stripes are easier to deal with and can be stripped and repainted. While the boot should be painted, I'm a fan of a vinyl cove stripe, which can then be changed more easily between paintings. Takes the pressure off color selection too, since it can be peeled back and redone.
Jeanneau 54DS
Don Casey: Paint Waterline Stripe with Bottom Paint asdf38 Gear & Maintenance 23 03-05-2016 06:50 PM
HVLP or Convential paint sprayer, & other paint equipment of choice patrscoe Gear & Maintenance 3 07-11-2011 11:46 AM
Valspar top side paint raayres18 Gear & Maintenance 7 11-12-2010 01:43 PM
Flaking bottom paint on 1 side, strip or repaint? FishFinder Gear & Maintenance 4 12-15-2008 09:20 AM
top side boat paint chuckg5 Gear & Maintenance 22 07-26-2006 09:32 PM
