Winch Maintenance - SailNet Community
post #1 of 2 Old 03-21-2012 Thread Starter
Winch Maintenance
We have a 1997 Beneteau 321 (new to us) The primary winches are Lewmar Ocean series 2 speed self trailing # 40s
Started to service winches (complete strip down)The problem I ran into I am unable to remove the largest gear set due to the positioning of the opening for the gear at the base of the winch and the position of the coming.Is there a trick to remove this gear pak without removing the winch base.
Is it feasible to file a pocket in the coming to allow the gear pak to slide out then gel cote the raw edges?
SawWhet is offline
post #2 of 2 Old 03-21-2012
Senior Moment Member
SloopJonB's Avatar
Re: Winch Maintenance
Dismount the winch and service it on a bench - don't start hacking at your boat to gain clearance. The mounting bolts probably need resealing after 15 years anyway. When you remount them you may be able to reorient them to gain the clearance for the next time you service them.
SloopJonB is offline
Barlow 15 winch maintenance brokesailor Gear & Maintenance 4 07-11-2011 09:43 AM
Winch Maintenance CalypsoP35 Gear & Maintenance 7 01-02-2011 03:38 PM
winch maintenance VictorJ Gear & Maintenance 3 03-26-2010 04:54 AM
winch maintenance Loualfr Gear & Maintenance 12 03-27-2009 05:17 AM
Winch Handle Maintenance tdw Gear & Maintenance 9 10-23-2007 07:42 PM
