tapered seacocks - SailNet Community
post #1 of 7 Old 03-22-2012 Thread Starter
tapered seacocks
I originally thought the seacocks on my p26 were old spartan ones. However now I'm not sure. There's no dog washer and there aren't any bolts! I am at a loss as to what is holding these things on to the boat besides some sort of 5200 like sealer. Any thoughts?
Leona - Pearson 26 - Annapolis
kjones is offline
post #2 of 7 Old 03-22-2012 Thread Starter
tapered seacocks
Pictures are in an album on my profile
kjones is offline
post #3 of 7 Old 03-22-2012
Re: tapered seacocks
Possibly flush bolted from outside??
Capt Len is offline
post #4 of 7 Old 03-22-2012
Most builders don't seem to have bothered with the bolts. The mushroom goes in from the outside, and the seacock is threaded onto it. So the mushroom and seacock flange are sandwiching the hull. It's pretty strong even without the mounting bolts.
MarkSF is offline
post #5 of 7 Old 03-22-2012
That's how the Spartan seacocks on my Morris were originally installed - no bolts, just
the mushroom threaded on.
MooGroc is offline
post #6 of 7 Old 03-22-2012
Senior Moment Member
SloopJonB's Avatar
I daresay the vast majority of hull valves are mounted that way - I rarely see them bolted on.
SloopJonB is offline
post #7 of 7 Old 03-22-2012
The thinking was the bolts keep the inside from turning on it's backing plate while the out side part screwed into the valve body. A big pipe wrench does the same job and FG is so tough, no problem.
Capt Len is offline
Tapered Plugs Squidd Gear & Maintenance 10 02-12-2012 12:29 PM
tapered plugs scosch Gear & Maintenance 18 02-20-2008 01:18 PM
tapered battens Randolph Bertin Gear & Maintenance 4 02-01-2007 06:55 PM
Tapered battens ltdavis Cruising & Liveaboard Forum 1 02-01-2007 06:05 PM
tapered halyards HAUK Racing 1 05-13-2003 05:45 PM
