Why doesn't anyone use propane refrigeration on a boat? - Page 3 - SailNet Community
 1Likes
post #21 of 29 Old 03-23-2012
Re: Why doesn't anyone use propane refrigeration on a boat?
Originally Posted by copacabana View Post
I'm not sure it's any more dangerous than a propane stove. Change all the gas lines and put in good quality shut-off valves and I can't see any problem.
The difference is that you should only charge the propane lines running through boat when you're actually using the stove. A fridge would need to be charged all the time. A leak could fill the bildge while your sleeping.
Jeanneau 54DS
Minnewaska is offline
post #22 of 29 Old 03-24-2012
mitiempo's Avatar
It's not a marine freezer. I believe it must be for the RV market (the brand is "Domec" I think).
It is probably a Dometic. popular in rv's in both Europe and North America.
As Minnewaska posted with a stove it is presumed you are there - with a fridge, often not.
I recall the Hiscocks aboard Wanderer had kerosene refrigeration - it had to be kept close to level to work properly. The propane fridges are similar, just the fuel is different. Virtually every rv has a 3 way fridge - 120volt/12volt/propane.
I doubt ABYC extends to Brazil.
Brian
mitiempo is offline
post #23 of 29 Old 03-24-2012
Yes, it's a Domitec 12v/120v/propane freezer, although I would never run it on 12v as it would drain the batteries. It doesn't seem to be at all sensitive about working 100% upright. I rarely release the gimbal and I haven't noticed any loss of performance when heeled. All in all, it seems a good solution, although I'm not sure I would have installed it in the boat as my first choice. It came with the boat, and "if it ain't broke ..."
I don't leave it running unless I'm on or around the boat. I suppose a gas sniffer with an automatic cut off valve in the bilge could be a solution to worries about an eventual leak.
Minnewaska, I never leave gas in the fridge or stove line. I have a valve right on the gas bottle that I turn off first and let the gas in the (very short) line burn off. Then I turn of the 2 individual valves, one on each gas line. The freezer also has a cut off valve if the flame goes out for whatever reason. I had a gas cutoff solenoid that I chucked in favour of high-quality manual shut-off valves, which I believe are more reliable.
Vindö 50
copacabana is offline
post #24 of 29 Old 03-24-2012
COPA, it sounds like you're doing the right thing, but assume you either have no refrigeration of use electricity when away from the boat. Just a further thought on a gas solenoid. They do fail and are only intended as an emergency shut off and need to be installed back at the tank. Ultimately, to protect the boat, you need to spin the tank value as you do. What I really worry about is a leak along the line somewhere.
Jeanneau 54DS
post #25 of 29 Old 03-24-2012
I like the option of a 3-way refer. Gas when sailing along. 12volt when motoring. Dock power when tied up.
You just have to make sure you dont blow yourself up. Simple enough. I sailed on an old timer built in 1898 that had kerosene refer - worked just fine as long as you kept the soot out and the burner clean.
My refer is 12v or 110 - works good enough for me. I can live for 3 days without charging batteries. 2 roll up solar panels - 1ft x 6ft takes care of my charging as long as the sun shines.
geoduck is offline
post #26 of 29 Old 03-27-2012
That should be obvious... there is waste gas... CO is produced and propane
is constantly depleted. 134A refrigerant is the current gas used. learn how to work with it.
Capt Mitch is offline
post #27 of 29 Old 03-27-2012
One of None
deniseO30's Avatar
Additional information if some of you may be interested.
Absorption cycle refrigeration and air have been around a very long time. Yes the company I was with serviced them. personally I knew very little about them except they needed simple gas burner service to keep the running. The larger units worked as a "Chiller" and cooled a brine (around 38*) that was piped to the cooling coil on top of a furnace or blower unit.
Absorption refrigerator - Wikipedia, the free encyclopedia
Labeled photo of a domestic absorption refrigerator.
1. Hydrogen enters the pipe with liquid ammonia
2. Ammonia+hydrogen enter the inner compartment of the refrigerator. Change in partial pressure causes ammonia to evaporate. Energy is being drawn from the surroundings - this causes the cooling effect Ammonia+hydrogen return from the inner part, ammonia returns back to absorber and dissolves in water. Hydrogen is free to rise upwards
3. Ammonia gas condensation (passive cooling)
4. Hot ammonia (gas)
5. Heat insulation and separation of water from ammonia gas
6. Heat source (electric)
7. Absorber vessel (water + ammonia solution
Back in the late 50s early 60s there were quite a few gas ac systems in residences and even full size refrigerators being sold and installed, mostly by utility companies.
On boat, in addiction to the dangers of gas and venting, the thing may rust out quick because of steel piping.
A flame is not really necessary to heat the system as I believe the temp needed to start the cycle working is around 240* (why the flame is so small)
Anyways... thought ya'll might like to do some "additional" reading
My last project!
deniseO30 is offline
post #28 of 29 Old 10-08-2015
We have an electric / propane regridgerator on our Gemini 105M. We love it. Connect to shore power on the dock and propane underway or at anchor. We are actually thinking about installing a second in one of the aft bunks (we rarely use) for longer voyages. As far as safety, I haven't seen any data that makes them less safe than electrical fires, seacock leaks, or any of the other dangers sailor face to live the life. Propane alarms, good maintenance and safety checks reduce the risk to a tolerable level. As far as that goes we already have a propane stove and barbecue. IMHO propane is safe, cheap, and efficient.
That said... The Gemini is a catamaran which means we don't heal over. (I'm still getting used to sailing level.) So maybe not the best choice for a monohull.
Sionnach is offline
post #29 of 29 Old 10-08-2015
One of None
deniseO30's Avatar
Old thread!
They are pretty safe but would not bode in a rocking boat. venting, lines, and leaks are the big concern on any Marine LP system since it lays low in the bilge and is slow to dissipate.
I've a friend that has a G-105
My last project!
Retro fitting a propane locker in a small sail boat downeast450 Gear & Maintenance 47 05-25-2016 05:13 PM
Refrigeration winethief Gear & Maintenance 15 11-26-2008 03:50 PM
Refrigeration recycle Gear & Maintenance 22 05-13-2008 10:09 PM
refrigeration paulsilva General Discussion (sailing related) 11 11-20-2007 02:05 PM
Boat Portable Refrigeration Stede Gear & Maintenance 5 11-22-2002 12:38 PM
