Why doesn't anyone use propane refrigeration on a boat?
RV manufactureres have been making refrigeration systems that run on 110V/12/AND Propane for many years. These systems are cheap and available everywhere due to the high number of RVs around.
Why have I never heard of anyone using propane refrigeration on a boat? I know these systems can last weeks on a modestly sized bottle of gas, which would remove the need for huge wind/solar arrays, Balmar alternators and AGM batts etc etc. There must be some reason right? I just can't think what it would be.....:D:eek: http://t0.gstatic.com/images?q=tbn:A...2Kncd7P0Or56VA Seriously though? What about using one of these: LP Gas Refrigerator - Norcold 323 on sale - PPL Motor Homes with all the appropriate sniffers/solenoid etc? MedSailor |
Re: Why doesn't anyone use propane refrigeration on a boat?
Probably for the same reason that ammonia gas refrigeration is avoided ... if you get a leak you get "!!!!". Propane gas in an RV if it leaks simply 'drains' to the tarmac; in a boat it 'drains' to the bilge. Propane 'sniffer alarms' arent 'foolproof'.
Its all a 'safety issue'. |
it is used on cats, like the Gemini 105Mc and houseboats. The issue is that propane fridges don't work unless they are damn close to level and above the waterline, two difficult requirements on a monohull.
If you park on a slope the RV fridge gets warm.eh. Then there's a down draft problem The electric side isn't as efficient as a compressor, me thinks. And then I think of BOOM. I've personally seen 3 boats and a house boat do the nasty. Oft gang aglee!
A propane frig doesn't need to be level as long as there is motion.... So sailing wouldn't be a problem.... The biggest issue is with safety.... Not only with a propane leak... But with the open flame required on a propane fridge....
I once used one on a boat. They do not work if not level. Even the smallest waves stop their functioning. If you are sailing they will not work for sure.
I have one in my boat and it works great. Mine is a freezer and I get about 25 days on a 13kg bottle of gas. Mine is gimballed, though I leave it in the locked position almost all of the time. I might release the gimbal if the boat is going to be a long time on one tack and well heeled, otherwise no problem. The flame has gone out twice in the 2 years I've owned the boat, but it has a gas cutter, so it hasn't been a problem. I'm not sure it would be my first choice if buying new, but it has worked flawlessly for about 15 years now, which is saying a lot.
We had a full sized front opening unit on Herreshoff NY 40 in the 70's but only used at anchor. Had forklift tank on deck. Kept the liquid assets at room temperature rather than on the rocks:laugher Safety is the big issue as well as the market it overwhelmed with 12v DC units and that's what builders and aftermarket promote.
boom
I'm not sure it's any more dangerous than a propane stove. Change all the gas lines and put in good quality shut-off valves and I can't see any problem.
| All times are GMT -4. The time now is 05:47 PM. |
SEO by vBSEO 3.6.1
