Thanks,
I knew I forgot something!
It is a 35' sloop (Holby Marine Clearwater model 1990). Currently the main halyard and reefing clutches and
winch are at the mast. I single hand a lot and the jack
lines and
harness are getting old (figuratively not really), I am just getting older but I still use them. I can bring the main halyard back on the starboard side where I have a
winch for raising the keel (it is a swing keel boat). There is one clutch there already for the keel
line (it is an old
Lewmar, there is about 700 lbs force on that
line, the keel is 4,000 lbs of lead and has a 7:1 reduction). I intend to replace that clutch that with a double I will bring the reefing
lines (2) back on the port side. I am rigging up a form of jiffy reefing with one line for each reef point. The mainsheet comes back there and there is a
winch for it, naturally, but no clutch. I am thinking of making it a triple, so I can lock off the main when I reef. That may not be necessary as you luff the main when you reef anyway, but I think it would look cleaner and I would feel more comfortable using the
winch for the reef lines if the main could not run out, currently there is only a fairlead for the mainsheet there, it locks in the self tailing winch. The boat is currenlty in the yard, I am guessing all these lines are 7/16 or 1/2".
