Backstay tensioner - just a fancy turnbuckle? - Page 2 - SailNet Community
 2Likes
post #11 of 17 Old 03-25-2012
Senior Moment Member
SloopJonB's Avatar
Re: Backstay tensioner - just a fancy turnbuckle?
Originally Posted by alanrothenbush View Post
But the thread MATERIAL .. hmmm. All stainless would be fine, but I suspect mine are the typical plated brass and might very well start to wear.
I think you'll find that non S/S turnbuckles are bronze, not brass. Most brass is too soft to serve in that function. Keeping the threads lubed with lanolin or anti-seize will help to preserve them.
SloopJonB is offline
post #12 of 17 Old 03-25-2012 Thread Starter
Thanks for the info about the turnbuckles. I knew it was some "yellow metal", just not sure which.
We bought First Edition two years ago, a return to sailing after more than 30 years away, and one of the first things I did was buy a tension gauge. That let me disassemble and inspect the rigging at deck level with some confidence of putting it back together again. And reassembly certainly did include lubing the turnbuckles.
I see you're from West Van .. I'm moored at Thunderbird! I had to smile .. your posting sig
"There is nothing half so much .."
is MY email sig and my goodness is it true.
I am simply astonished at how much time I spend working on her .. dockside and at home .. and LOVING every minute of it.
Part of the seemingly endless list of tasks comes inevitably from buying an older boat, part from the fact that previous owners really didn't know what they were doing with their various mods and tweaks and most from the fact that I just can't resist!
Thanks again.
Alan
alanrothenbush is offline
post #13 of 17 Old 03-25-2012
SloopJonB's Avatar
Thanks again. Alan
Years ago I read an interview with a boat builder - I think it was a Hinckley - wherein he said that if he had to choose between only working on them or only sailing them, he would choose working on them. I would find it a VERY tough choice to make.
My 43 is in Race Rock - drop by some time.
post #14 of 17 Old 03-25-2012
Liquorice's Avatar
Here's 8 possible backstay configurations from the Harken Catalogue:
Harken Tech Corner: Backstay Adjusters
(including Jacks)
Most small to medium sized sail boats have one of these. Your boat won't need anything different.
If you don't like Jacks safety strop idea, do a split backstay. That way you have wire all the way and the adjuster just pulls in the split ends.
As one of the other replies said, the treads on an adjuster are different. They are "Acme" threads and have a much stronger thread profile (flat top) so they can take much more tension without "pulling out".
sam :-)
sam :-)
Just because you're paranoid ...doesn't mean they're not after you!
Liquorice is offline
post #15 of 17 Old 03-25-2012
Does a cruiser really need an adjuster? Why not just use a turnbuckle and adjust to medium tension?
The Sun has Risen on a New Day filled with the Promise of Adventure.
CapnBilll is offline
post #16 of 17 Old 03-25-2012
jackdale's Avatar
Being able to flatten a main with an adjuster and the outhaul is a bonus. Rather than reefing with a small wind increase, flattening the main will depower it just enough. A little cunningham is an extra bonus.
jackdale is offline
post #17 of 17 Old 03-25-2012
Lake Superior Sailor's Avatar
Check it out Ebay # 37059886544 might do the trick!..Dale #370557802479
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
Tags
backstay tensioner
Anyone recognize this part? Jp3 Backstay tensioner sandycohen Gear & Maintenance 5 05-27-2011 03:10 PM
Anyone fancy a cheap ALI 70 footer TQA Boat Review and Purchase Forum 2 08-03-2009 10:09 PM
Fancy Meeting You Here! BugsBunny Introduce Yourself 0 05-29-2009 02:19 AM
Fried My Backstay Tensioner? SEMIJim Gear & Maintenance 10 10-18-2007 08:20 PM
Full Batten Tensioner jimgregory General Discussion (sailing related) 1 06-06-2001 09:02 AM
