Dyneema Lifelines Installed - SailNet Community
 3Likes
  • 2 Post By Squidd
  • 1 Post By Squidd
post #1 of 10 Old 03-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
The coated steel lifelines I had were cracked every inch or so with sections of covering missing where it passed thru the stancions and "frays" of wire poking out along the length...
I read about the Dyneema Line being approved for use on racing boats so I thought I'd give it a try...(not to mention it's relatively inexpensive)...
On the Bow Pulpit I made a Brummel Splice and luggage tagged it to the loop...
Strung it thru the stancions and put on a layer of "tubular webbing" chafe guard and secured loose ends with a piece of shrink tubing...Keeps the webbing from unraveling and helps it slip thru the stancion when I un clip the line...
On the stern pulpit I used a pelican clip, ordered in an SS eyebolt of correct thread... I double whipped the loop of the eye with Dacron to cushion bend and attached with a regular push splice cross sewing to keep it from pulling out...
Pulled tight when I marked the loops and still have a few inchs of threads to adjust tension on Pelican Hooks...
Looks Better, no "pokies" and matching color...Whole project under $100..
davidpm and mitiempo like this.
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #2 of 10 Old 03-24-2012
davidpm's Avatar
Re: Dyneema Lifelines Installed
Looks great, thanks for the pictures.
Where did you buy the stuff.
davidpm is offline
post #3 of 10 Old 03-24-2012
Lake Superior Sailor's Avatar
Worked out nice & looks good too! Seems like you will be ready Soon!--Good Job! ..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #4 of 10 Old 03-24-2012
GreatKetch33
Deric's Avatar
Add Content
Deric is offline
post #5 of 10 Old 03-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
E Bay...Actually a Dyneema SK-75 winch cable/line came with a 4' section of chafe webbing... under $50
"Captin Ron"
Squidd is offline
post #6 of 10 Old 03-24-2012
pdqaltair's Avatar
Where did you find the eye-bolts (I'm assuming it is left hand thread, which is a trifle hard to find in SS eye-bolts)?
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #7 of 10 Old 03-24-2012
Hi Squid ... Looks great and a nice way to go NO rust to follow up on .. Paul
Chkm8 is offline
post #8 of 10 Old 03-24-2012
bljones's Avatar
Good work!
It even comes in under the $100 Low-buck threshold. Mind if I borrow this idea?
It's 5 o'clock somewhere:
bljones is offline
post #9 of 10 Old 03-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Took some looking...Not left hand but UNF which added to the challenge and I wanted 2 1/2"-3" thread length not just 1" on end (for adjustment) ...Fastenal, Granger and McMaster Carr fell thru, but I found them at a specialty SS fastner co..."Unicorn Stainless"...
"Captin Ron"
Squidd is offline
post #10 of 10 Old 03-24-2012 Thread Starter
Superior Sailor
Squidd's Avatar
Originally Posted by bljones View Post
Good work!
If promise not to call me "junior" anymore...
I was thinking of throwing my hat in the Low Buck Thread anyway, I got a couple of them...
"Captin Ron"
Squidd is offline
Dyneema lifelines AdamLein Gear & Maintenance 45 04-16-2012 10:00 PM
Dyneema Lifeline Hooks Squidd Gear & Maintenance 6 03-15-2012 01:54 AM
1/8" Dyneema for Jacklines? KeelHaulin Gear & Maintenance 3 05-24-2010 05:33 PM
Dyneema eye splice bobmcgov Gear & Maintenance 16 03-07-2008 12:53 AM
