Diesel Starting - Glow Plugs - Page 2 - SailNet Community
 6Likes
post #11 of 22 Old 11-28-2012
Re: Diesel Starting - Glow Plugs
Recently I went to start my 3 cyl diesel. It had been about two weeks since last started and I was concerned that I might not have enough juice to turn her over. I always have a hard time starting my diesel when it's on the cool side. Sooooo I just rolled the engine over a time or two and determined I had plenty of electricity in the batteries. Then I held the glow plug button in for my normal time then the starter. It started up faster than ever. Normally I hold the glow plug button in for 20 - 30 seconds then the starter and it grinds and grinds usually starting. I believe that in the past I have been heating an empty cylinder. By cranking it first it allowed fuel to enter the cylinders to be heated.
William E. Heritage is offline
post #12 of 22 Old 11-30-2012
I have an older (1988) Universal that starts well in the summer with about 5 to 10 seconds of glow plug. I run the electric fuel pump first for a few seconds then the glow plug then the starter and she fires right off. I only use the glow plugs first time for the day after that it starts quickly without them. In winter with air temp in the 50's I run the glow plugs a little longer. Haven't sailed in colder weather yet.
H and E is offline
post #13 of 22 Old 11-30-2012
Oaksail's Avatar
[QUOTE=MarkSF;850217]Both direct and indirect-injection engines have glow-plugs. Whether we like them is beside the point, the engine won't start (or is very hard to start) cold without them.
My direct injection Volvo Penta 2002 does not have glow plugs. Takes a little extra cranking in the cold but otherwise starts right up.
1989 CS30
Oaksail is offline
post #14 of 22 Old 12-01-2012
I have a 3ym20 and there is nothing in the manual about glow plugs, I was also told they did not use them. I did read in the manual to put the throttle full on to start and cut back as the engine revs. Makes a big difference in starting.
Mark1948 is offline
post #15 of 22 Old 12-03-2012
Zanshin's Avatar
Originally Posted by Oaksail;955105...My direct injection Volvo Penta 2002 [U
does not[/U] have glow plugs. Takes a little extra cranking in the cold but otherwise starts right up...
Which engine do you have - I went to Volvo Penta's page and chose 2 marine engines at random and both have glow plugs.
Zanshin is offline
post #16 of 22 Old 12-03-2012
Oaksail's Avatar
Hi Zanshin,
2002 is the model number. 2 cylinder
2003 is the 3 cylinder
1989 CS30
Oaksail is offline
post #17 of 22 Old 12-03-2012
Oaksail's Avatar
Hi Zanshin,
i found the document, link below
http://www.bottrell.ca/images/Volvo2...hureA41987.pdf
1989 CS30
Oaksail is offline
post #18 of 22 Old 12-03-2012
Zanshin's Avatar
Oaksail - I looked at the shop manual for the D1-20 engine (the 2002 2-Cyl 18HP one that I think you have) and it shows me where the 2 glow plugs are installed on page 46.
Manual : http://www.maritimsd.no/Customers/ms...20Volvo/D1.pdf
Zanshin is offline
post #19 of 22 Old 12-03-2012
Maine Sail's Avatar
D1-20 is different from the 2002. The Model 2002 does not have glow plugs..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #20 of 22 Old 12-03-2012
Oaksail's Avatar
Thanks Maine Sail,
I just discovered too during an injector cleaning that this Volvo model with copper injector sleeves does not use copper washers to seal the gap between the injector and cylinder head.
1989 CS30
Oaksail is offline
Glow plugs Classic30 Diesel 12 08-09-2010 06:49 PM
Do all diesels have glow plugs? harbin2 Diesel 18 06-27-2010 11:02 AM
Glow Plugs primerate84 Gear & Maintenance 4 05-23-2010 07:40 AM
glow plugs TheThrill Diesel 22 05-21-2010 02:20 PM
Diesel Problem: Glow Plugs in a Nanni (Mercedes) RichH General Discussion (sailing related) 1 04-21-2003 09:06 AM
