Cleaning winches - SailNet Community
post #1 of 8 Old 03-24-2012 Thread Starter
Cleaning winches
I broke down, cleaned, relubricated and reassembled all my winches today. Two Harken powered 66s, one powered 46 and one reg 46. The first 66 took me two hours. The next was easier, maybe an hour. By the time I got to the last, I was a pro. This will start all over next year.
I'm now ready to do yours if you like. My rate is $1 million......each.
Question. How often do you change the pawls and springs? I bought all new, but they would not actuate well and I just put the old ones back, which actually looked fine. Don't know why the new set was so finicky.
Jeanneau 54DS
Minnewaska is offline
post #2 of 8 Old 03-24-2012
CaptainForce's Avatar
Re: Cleaning winches
I've changed springs, but not pawls. I haven't lost little pieces during my work myself, but I have heard of the technique of placing a cardboard box with a hole cut in the bottom over the winch to provide a work space that will confine anything dropped or springing away. Take care and joy, Aythya crew
CaptainForce is offline
post #3 of 8 Old 03-24-2012
ASA and PSIA Instructor
Change the pawls when the edges of the pawl start to get rounded. I dont change the springs until they dont open crisply or more likely break.
sailingfool is online now
post #4 of 8 Old 03-25-2012
Well, I agree, but for some reason my pawls have never dulled or rounded, but my springs break or lose form. What's with that?
post #5 of 8 Old 03-25-2012
I've done some design work with springs. Once you do all the calculations and see what a properly designed spring looks like you realize that a lot of the springs you see are improperly designed. The biggest problem is over extending a spring, which causes metal fatigue to set in. The proper spring would take a lot more space, so they compromise and expect them to be replaced regularly. There is a lot of research that indicates if a spring has stretched 1 million time without breaking, then it will never break!
Gary H. Lucas
GaryHLucas is offline
post #6 of 8 Old 03-25-2012
Gary M's Avatar
I do my winches once a year, maybe twice and replace pawls and springs if they are damaged or if they look or feel weakened. They are not expensive so go for it.
Gary
Gary M is offline
post #7 of 8 Old 03-26-2012 Thread Starter
A new set of pawls and springs are about $32 per winch, so they add up. My old pawls were nearly indistinguishable from the new set. The edge that rides over the gear is slightly rounded on the new set to begin with.
Anyone ever have trouble with a replacement set not working properly? Some new ones would stick, so I just put the old ones back.
Jeanneau 54DS
post #8 of 8 Old 03-26-2012
Just did mine last week. 2 springs had to be replaced but no pawls. The pawls in mine have been in since I bought the boat back in 2000. Still look and work good.
Dennis Miller
S/V Mustang
S2 9.2A
Jacksonville, FL, USA
SantaSailor is offline
winches from a 41' '79 QuickMick Cheoy Lee 0 06-15-2010 11:55 AM
new winches ambianceack Gear & Maintenance 4 06-14-2010 10:20 AM
Stupid Newbie/beginner mistake cleaning winches saurav16 Gear & Maintenance 24 07-02-2007 10:26 PM
